Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
My LGT2654 will run fine for 20-30 minutes and then revs down a couple times and shuts off. It will start but it revs up and down and then clears for a little and will go thru that process again. I need to find what is causing this
  • 927 Answers
Try removing the gas cap when it begins to stall.
If the idle improves, clean the vent holes on the gas cap.
Let me know.
Gary
Posted on May 27, 2011
Fuel system running rich and stalling
Sounds like it is slightly out of time.
Apr 14, 2014 | Ford Cars & Trucks
1999 suzuki quadrunner does not run properly
Sounds like its floodling check the carb for dirt and clean well, check the float is still floating, check for wear on the float valve, seat and seal.replace if nessary.
Jan 27, 2012 | Motorcycles
I have a generac 6500 r/v generator 6 months old with @ 50 hours on it. The generator starts and runs fine for 10 minutes and then revs very high. Some times it will rev up and down like it is searching...
Make sure all the linkages and springs are hooked up on the throttle system and where they pivit is clean. Try moving the linkage by hand gently to make sure there is no sticking and litely oil where the linkages connect. If everything is working properly your internal governor has to be replaced.
Mar 15, 2011 | Electrical Supplies
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
Mar 15, 2010 | 1999 GMC Yukon
Engine revs high then low then stops
check the governor lever. it prob sticking or gone.
Aug 04, 2009 | Toro Lawn Mower With Toro Power Tools
Briggs & stratton 26HP engine is reving up and down after 30 min
I removed the engine and broke it all down last night. Inside the engine I found a mole. Once I removed the live mole and cleaned the valves - it worked fine.
May 13, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
362 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
