Question about RCA CDRW120 2-Disc CD Recorder
I NEED THE SCREW IN LEGS FOR THE UNIT WHERE CAN I FIND THEM
    Problem Solver:
  • 7 Answers
You could try contacting the manufacturer
they may be able to provide spares
http://www.rca.com/
darren
Posted on May 28, 2011
Can you adjust the height of the KID60B14 dishwasher?
Hello Jane!
Remove the bottom kick plate on the front of your unit. There should be screw-adjustable legs on each front corner with a toothed wheel. Find a lever and suitable jack point on the frame to raise the unit to desired height and if the adjustment legs are not "frozen" you should be able to turn them with your fingers.
If they won't turn easily, apply some light oil or WD-40 and let it work on the corrosion for a few minutes and try again. If the adjusters are jammed, you may need pliers to turn them.
You may also go straight to pliers without raising the unit first, but the adjustments are more difficult since you are lifting the entire unit.
Oct 24, 2016 | Dishwashers
How to raise height on stove
adjustable feet (legs) on bottom. If you need it higher, use a strip of wood, the required thickness, on each side cut the full length from front of unit to back wall and approximately 5" wide. Screw it down so the unit can be easily removed when need for cleaning and servicing.
Aug 20, 2014 | Kitchen Ranges
Kenwood dishwasher
You will have to remove it from its installed location. This means unhook the water supply and drain hoses. Then you pull the screws out that hold it to the counter top. Then slide the unit out until you can see the back. The rear legs usually screw in and out to raise and lower the unit.
Aug 01, 2014 | Kenwood KDW243A Builtin Dishwasher
Can I put my telescope on a new tripod
it it has a center screw for attachment then check with camera shops ( normally sell telescopes and accessories ) as to what the screw size is for the sturdier tripods
could be a simple case of a new screw to suit your unit in a new tripod
Nov 09, 2017 | Takahashi Optics
I have a LG LD 2140WH diswasher, it only works for 2 min then give a OE error code. what can be wrong
The possible reasons could be
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
May 27, 2011 | LG Dishwashers
I want to wall mount a FX2490HD and cannot remove the base I have remove the screw form the back but the base will not move
Hi, there are two screws underneath the legs of the stand and one other screw to hold the attachment that the legs connect to. If you have removed all three screws then try swiveling the legs.
Feb 12, 2011 | Samsung Televison & Video
Open door and whole unit moves, it dosen't come with back legs, or does it??
No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
Hope that helps,
Good Luck
Oct 31, 2009 | Kenmore 60721 Refrigerator
My Admiral washer machine moves and shakes all over the place on the spin cycle what is the problem
It needs to be rebalanced.screw the front legs down first tilt the machine up from the front slighltly to automaticly re adjust the back legs (shouldnt be any screw legs there) then manualy re adjust your front legs. this happen a lot when you wash big loads or blankets and such etc. and is normal glad to help you
Jan 08, 2009 | Admiral AW22 Top Load Washer
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
RCA CDRW120 2-Disc CD Recorder Logo
16 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
