Question about Baumatic Refrigerators
I have a baumatic fridge freezer model no bfe256ss it is not keeping food cold freezer is defrosting, display showing 5 on freezer 18 degrees on fridge. Tried quick freeze, holding buttons, turning on and off from plug. Please help!
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
  • 70 Answers
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Posted on Aug 10, 2010
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The cooling in my fridge is haywire! The freezer gets frosted and the fridge is warm. I've taken everything out and let the frozen blockage melt but in a few days it's happening again. It is only @4 years...
remove the inside rear wall panel in the freezer and check both the defrost heater under the evaporator coil and the defrost thermostat on the upper side of this coil the heater will show resistance if good and the thermostat will show 0 ohms like a switch if good(but must be tested under 32 degrees to be closed)you can defrost these parts quickly with a hand held hair dryer for quicker dis-assembly and repair
Jan 26, 2011 | LG Refrigerators
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Kenmore Fridge, freezer compartment is cold according to thermometer, but ice wont freeze & frozen foods thawing out, weird. Fridge part is about 65 degrees. What could it be?
Should be around 10 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Refrigerators
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Baumatic Refrigerators Experts
Sal De
Colin Stickland
Colin Stickland
richie46
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
