Question about Samsung 7.3 Cu. Ft. Electric Dryer
Dryer starts then stops. Code flashes on control board.
My Samsung DV306LEW is less than two years old. It starts and then roughly ten seconds later starts beeping and a code comes up on the digital display stating that there is a heater temperature control issue.
What can I do to repair this problem? We have contacted the services center and they stated it would cost $285 to look at and work on the issue. This did not include the part price.
  • 876 Answers
Do you clean the lint filter after each use? If not, please do so now.
Next pull out the dryer and look for kinks or squishing of the big rippled six inch exhaust hose. You can take it off by unscrewing the clamp tht holds it onto the dryer and then clean it out. it may be clogged. You can also go outside to the external vent and check it for a clog.
Another thought is that the WASHER is not spinning enough water out of the clothing so that the dryer gets very hot trying to dry them.
I hope this helps. I'll have alook at the manual if I can locate it while you are doing this. Does it give you a code number?
Posted on Aug 16, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 16, 2008
    Okay, the instructions in your manual say exactly the same thing that I did. If this does not work, you need to call a repairman. Overheating in the dryer can cause big problems. Do make sure that your washer is spinning the water out adequately though, so that you can inform the technician of that if it is a problem also.
    Good luck to you!
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
Why did this part fail again?
this fuse usually blows when the dryer gets too too hot. It is there to pop before your dryer starts a fire internally!!! Make sure that your element is good and not sticking (meaning the element popped and stuck to the housing causing a false connection for the coil to run through). if that isn't the problem then make sure your dryer vent in the back is not clogged up and air flow is not blocked!!!
May 21, 2014 | Samsung DV306LEW Electric Dryer
Leq1442eso
Good Afternoon Terry, thank you for your post!
Often constant beeping is an indication that the unit is experiencing a possible error. I under you have tried resetting the dryer by flipping the breaker. It is important to wait roughly ten minutes before turning on the unit. If the beeping continues, then the appliance could be experiencing a communication issue with the control board or a potential wiring failure. I would recommend connecting with a qualified appliance repairman to proceed further.
Aug 29, 2013 | Frigidaire FEQ1442ES Electric Dryer
My samsung dryer model DV306LEW keeps cutting off and giving us an error message
It is probably over heating. This fancy dryer is nothing more than a Maytag dryer. The blower wheel could be loose.
Here is your SERVICE MANUAL
Jul 07, 2012 | Samsung DV306LEW Electric Dryer
The dryer will run for a couple of minutes and then it alarms, stops, and gives me an error code. The code looks like an upside-down F and a zero.
The error code is tO. You have a thermistor problem and needs a technician to help you determine which one has failed.
Jun 17, 2011 | Samsung DV306LEW Electric Dryer
10 year old sears kenmore elite dryer, PF light will not stop flashing even after holding start for 10 seconds or after holding stop button for 10 seconds
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Dryers
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Samsung 7.3 Cu. Ft. Electric Dryer Logo
696 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
