Question about CTG Auto T-Switch
My car heater fan is not working - CTG Auto T-Switch
What car is it? It can be a small problem either a fuse for the blower (you can check the fusebox yourself) or its behind the switch...is the fan not blowing at all? it can be either the switch itself
Posted on May 27, 2011
The heater fan in 2008 uplander will not work
Does the switch works in other modes ( ac, def ) If not , ck power & ground at the fan itself in all modes., If OK R/R the fan. If the fan only loses power or ground in heater mode look toward the wiring------switch control. Good Luck.
Feb 13, 2016 | Cars & Trucks
Ac/heater stays on after car is off and key is out 2000 ford explorer
sometimes,and some cars have a blower motor resistor that goes bad.Check and see if you have one,replace
Jan 06, 2014 | 2000 Ford Explorer
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
No fan operation on867819221 ac
It can be issue with relay or wiring of the fan causing the problem.
Check the help links.Click the link below:---
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater AC or defroster fan not working on KIA? http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
Where is A/C CONDENSER FAN MOTOR RELAY Located? http://repairhelpcenter.blogspot.com/2011/11/where-is-ac-condenser-fan-motor-relay.html
How to Remove Fan Clutch ?
http://technoanswers.blogspot.in/2012/04/how-to-remove-fan-clutch-on-2005-gmc.html
This will help.
Thanks.
Jul 17, 2012 | Cars & Trucks
Heater fan not operating
Most of the time when a heater blower quits working it is the blower switch that fails rather than the motor. Blower switch can be accessed in the dash panel.
Feb 25, 2012 | 2004 Chrysler Pacifica
BWM heater problems--display and switches working but no fan
your fan speed regulator located on your heater core box is bad if its just one or some of the speeds. if the fan does not work at all its either a bad connection to your fan speed regulator or the fan motor has quit. out
Jan 26, 2010 | 2000 BMW 3 Series
Heater wont work a fuse maybe? some how I doubt it. the rear window heater works. fan dead perhaps? no fan at all. not sure about heat.
Hi: Sounds like a possible heater resistor problem. First check to see if heater fan working, unplug heater under hood and put 12 volts to it from the battery with a wire (single black wire running to back of fan). If works then problem probably the resistor which is located on the fan housing under the hood to the right of the fan. The resistor has wires to it running from the heater fan, 2 - 7mm screws holding resistor in place, check resistor to see if any of the 3 elements are melted off, if so replace. Note: Rear window defrost has nothing to do with heater fan. Hope this helps...
Feb 26, 2009 | 2002 Chevrolet Blazer
Heater stopped working
The heater core has gone out and will need to be replaced
Dec 07, 2008 | 2002 Mazda Millenia
1999 Dodge Caravan...heater works but fan will not blow
You most likly need to replace the fan or possibly the fuse for the fan blew.
Nov 28, 2008 | 1999 Dodge Caravan
CTG Auto T-Switch Logo
42 people viewed this question
Top CTG Computers & Internet Experts
Vuk B
Are you a CTG Computer and Internet Expert? Answer questions, earn points and help others
