PC boots up very slowly and fan is very loud. Once up, it powers off after about 15 mins or so of use. Replaced power supplt last year.
  • 1,591 Answers
If this is a name brand system like DELL it probably needs to have the CPU heatsink cleaned, and put new thermal grease between the heatsink and CPU.
It's slow because it's speed stepping the CPU to a lower speed because of overheating.
The heatsink grease is almost always the issue here.
Posted on May 27, 2011
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
02 envoy, 6 cyl, loud wooshing noise when engine is cold. fan clutch seems fully engaged. goes away when engine warms up. is this normal or does fan clutch need replaced
Fan clutches for Envoys and Trailblazer are a problem, they go out all the time.
However, it is normal for it to do this when cold, but will only stay engaged for maybe 15 seconds AFTER you've put it in gear and have started to drive. After this, it will disengage and allow the engine to warm up faster.
If you haven't already replaced the fan clutch once, you're lucky. 2002 is especially bad for the clutches, but all years don't last long. Mine lasted 90k which is pretty long.
Feb 26, 2011 | 2002 GMC Envoy
When I press the power button to start my 3000 K100, the fan starts and then stops immediately and the PC will not boot. There is also an odd odor like something burning. I had the power supply checked...
Open your PC case and look at all the round little tubes around your CPU fan area. They are called Capasitors and if any of them are bulging or have a brown crust on them they went bad and will need to be replaced. I've had many of PCs come in with this issue and once the caps are replaced the PC works fine again.
Hopefully this helps you out. Best of luck..
Nov 19, 2010 | Lenovo 3000 K100 57061308 Intel Desktop...
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
PC won't boot (no signal and no beeps)
check the board for blown capacitors. I have found many boards from power circuits to motherboard with popped capacitors over the past 5 or so years. replace them and tada, it lives again. I've been successful several times with this operation. Please see the picture below for a guide to finding bad caps.
Jan 02, 2010 | Intel Motherboard
Computer won't turn on already replaced power
Try unplugging the PC for at least 10 mins. If that fails... it could be the BIOS failing to Boot. Leaving it unplugged my discharge the System and it may Boot, once it does it maybe best to update the BIOS. If the continues it will force you to replace the BIOS or the Motherboard. If the System is older than 3 years, I would replace the Motherboard and reinstall to a new hard drive and recover your data. Or buy a new system and recover your data by using a USB external HD Container.
Dec 30, 2009 | HP Media Center PC M260n (DF200A#ABA) PC...
Emachine t6420 suddenly shutting down after about 15 min. - 1/2hr. Power button on HD blinking on and off slowly. Can get it to start up again by taking out the electric plug and waiting a min. and...
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Sep 28, 2009 | E-Machines T6420 PC Desktop
I've got an Acer t650 desk top. Normally boots at the push of the power switch but has developed problem where by it doesn't boot first time all you get are fans but then it will burst into life and work...
Check for virus first You could have a boot record virus. that said, once the system comes up, backup your files on say a 4gig USB stick. and reinstall the OS or if the system comes with recovery SW use it and rebuild the system.
If you still have problems, you may have to resort to a new Motherboard. ie (mainboard).
I got news for you they are not that hard to change out.
take a few digital photos of the board before you pull it apart.
Make sure you get the right board. CDW could help you with that. and go one for one with the replacement.
It's not as hard as you think.
replacing a MB takes less than 20 min.
I've replaced over 4000 of them from Laptop to desktop to servers in the past 15 years. they have gotten easier in recent years. just make sure you use a static (grounding) strap when doing this. A carpet shock to a computer component is equivalent to you or I getting hit by lighting. even the ones you never feel will distroy the smaller components over time.
goodluck
44hink
Jun 03, 2008 | Acer Computers & Internet
Dimension 8400 will not boot, very loud fan.
I have a small business where I have worked on PCs for the past 14 years. I have had some of my clients that have brought me a few of these Dell 8400 to work on with the same problem. Will not boot and loop the start up, along with sounding like a leaf blower. After much trial and error i.e. Heat sink,cooling fan, power supply and motherboards. The first one I worked with by changing the heat sink, worked for about a week, then started doing the same thing. Replaced the Power supply with no results, same issue. Next was the Motherboard, still same issue. Last I pulled the processor out and found that the processor had over-heated and was damaged. In all I had well over $500.00 dollars invested and countless hours. Still the machine did not work, and still needed more work. Since this time I have had a few more of these machines cross my path. My suggestion is to scrap it and purchase a new PC. This is not one of Dell's better designs, and there is a tech issue from Dell related to this problem with the heatsink and the machine itself in the tech support on the Dell site. It states that they had a bad batch of heatsinks, but only replaced them under warranty.
Salvage what you can and build or have someone build you a clone.
Apr 04, 2008 | Dell Dimension 8400 PC Desktop
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
