Question about Kenmore Dryers
I need to replace the Switch, Push-to-Start/Option on my Kemore Gas Dryer model number 110.97576410.
  • Kenmore Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on May 27, 2011
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
I have power to the dryer and it allows me to choose drying cycles but when i push the knob in to start the dryer it has an error code of "DO" and will not let the dryer start. I have tried to unplug the...
DO stands for Door Open.
Check on the inside of the door and insure that the plastic tab-like, finger-like actuator that fits into the slot on the dryer is still there and not broken.
This tab is what pushes in the door switch on the dryer and let's the dryer know it's safe to start. If it is there, you could have a bad door switch or control board.
I'd suspect the door switch first.
You can take a flat-head screwdriver and stick it into the slot at the door switch while pushing start to see if the dryer runs. If it does, you're door switch is ok. If not, we need to replace the door switch.
I can help you further by getting you part numbers and part-ordering information, but I'll need the make and full model number.
Try those tests and get back to me?
Best, G
Aug 04, 2010 | Maytag Neptune MDG9700A Gas Dryer
I replced ingnitor in my kemore gas dryer but not flame
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Jun 30, 2009 | Kenmore 75944 Gas Dryer
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kemore he2 won't start
check the door switch make sure that it clicks when you push it. if not its probably not working
Jan 06, 2009 | Kenmore 82822 Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kemore dryer model 96591220
i lovkkekmgkrt,mfgkdgm
trlfdlmgd,mkklr m
frlegtmrkhgm
r,lthntytgm
bgfmlnhjn,fds,ldld.,ddlrfkvbgfd lmmlg
gllf
flgf
fkg
dfkgkmkdff, k,gmh,mghkmkgmkfgmkfgmgkmghkhmgkfmkgmfk,gfm
Feb 12, 2008 | Dryers
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
