Question about Masterbuilt 20070106 Electric Smoker
In the recipe for Baby Back Ribs, the timing is 3 Hrs at 225 degrees. Does the cooking time start when the smoker reaches 225 degrees or when you start the smoker digital timer? The time it takes to get to 225 is usually 30-60 minutes so that would be quite a difference on cooking time depending on when you star the timing
  • 43,501 Answers
Three hours of cooking @ 225.... start the timer after reaching temp.
heatman101
Posted on May 27, 2011
My ribs came out done but not fall off the bone tender. What cAn I do to achieve fall off the bone tender?
For pork ribs, start by cooking them for 2 hours, at 225, internal temp 160 degrees, then remove from the cooker and foil them.
Be sure to put some of your mop juice, or apple juice inside the foil packets to help them steam and get tender.
Smoke them in in the foil for about 1:45 to 2 more hours. Remove the ribs carefully and vent them. They will be fall apart tender now, and fragile. Let them sit.
After about 10 minutes they will have firmed up again enough to move them back onto the grill for glazing. Use some sauce or a finishing rub to taste.
Feb 16, 2015 | Grilling
How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
Hi karin 1967...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Sep 24, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
Sep 18, 2011 | Grilling
How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
Hi hcf6886...
There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
Hi dan480volts...
Maybe this will help you
Sep 16, 2011 | Masterbuilt 20050106 Propane Smoker
How long and at what temp do i smoke rims with the masterbuild smoker
Hi todd649...
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
Sep 05, 2011 | Masterbuilt 20070106 Electric Smoker
How long do i need to smoke ribbs
Depends on how many pounds you're smoking, as well as are they pork or beef? Country style or Baby Back? And how much smokey flavor to you want?
Baby Back Pork Ribs require the least amount of time, as they don't have as much beat on the bones as Country Style Beef ribs Never-the-less, my own personal theory of smoking meats is "Low and Slow." "Low" meaning no more than 225 to 250 degrees. "Slow" meaning at least 2 to 3 hours for Pork Baby Back Ribs. 4 to 6 hours for Beef Country Style Ribs.
The first 30 minutes to an hour time the crucial for smoking. That's when the fibers or the meat are most open and will absorb the most smoke. After that, you're basically slow cooking for tenderness.
Always wait until the last 30 minues to brush or mop on any BBQ sauce.
Seasoning the ribs prior to smoking is very important. Whether you use a dry or wet rub. The choice is yours. Once the rub is applied, warp it tightly in plastic wrap and refrigerate for at least 2 hours. Over night is better. Take the ribs out of the frig, unwrap them and allow them to come to room temperature before placing on the smoker. That way, the meat fibers will open some.
Once on the smoker, DON'T PEEK! Every time you open the lid, you loose smoke and heat. You want to try to maintain that 225 - 250 degrees without loosing it and having to bring the smoker back up to temperature.
Once you remove the ribs or any kind of meat, for that matter, let it rest for at least 5 minutes before cutting it. That way, you won't loose all those delicious juices.
The weekend is not that far off, so start planning now and enjoy the fruits of your labors, this weekend.
Hope this helps to get you started. Please let me know how they truned out. Or better yet, send me a sample to taste. :-)
Mar 01, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Cooking Time
Google "Smokering" and you will find a lot of forums dedicated to smoking food. It is an art in itself but many of these forums are helpful in learning.
The answer to your question is basically put as many racks of ribs that fit without touching and as long as the temperature is maintained they will all cook at the same time. I typically smoke my ribs at 225 for 4-5 hours.
May 24, 2010 | Masterbuilt 20050106 Propane Smoker
I have a 23 pound turkey how long to cook and what temp do you use
There is no definite time.It is extremely important that the internal temperature of the turkey reach at least 165 degrees in order to kill harmful bacteria that may exist. Thi includes the stuffing. This if difficult to do without drying out the whole bird. Without Stuffing in the bird it is easier. Cook the turkey until the breast meat (thickest part,not near bone or ribs) reaches 161 degrees. or between thigh/leg reaches 180 degrees. Check out http://www.foodnetwork.com/recipes/alton-brown/good-eats-roast-turkey-recipe/index.html , see how its don link in the recipe. Happy Thanksgiving
Nov 25, 2009 | Office Equipment & Supplies
Masterbuilt 20070106 Electric Smoker Logo
327 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
