Question about Garden
We have a master craft 12inch maximum dual bevelmitre saw with laser, came with a 12 inch blade with a 5/8 arbor, apparently they don't sell 12 inch blades with 5/8 arbor, only 1 inch. apparently saw comes with some sort of flange or size adjuster, cann't find it anywhere, nor can i find my manual. Help! Vicki
  • 843 Answers
You need a saw blade bushing. It looks about like a wedding ring with a 5/8 id (inside diameter) and a 1 inch od (outside diameter). I did a quick google search and found this: http://circlesaw.com/xcart/1-to-5-8-Saw-Blade-Bushing-p-5036.html
Good luck. Please vote if you found this helpful.
Posted on May 27, 2011
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
How many teeth can my blade have
There is no maximum teeth count you can use. Just make sure the blade isn't too big for your saw and the arbor fits properly.
Jun 14, 2012 | Saws
How to change blade arm and plastic blade guard
Don't forget that the bolt that holds the blade against the arbor (the motor hub connection point) is threaded COUNTER-CLOCKWISE. This is the opposite of nearly everything else we encounter. Be sure to use the two wrenches you got with the saw, and like the directions always say, "Unplug unit before servicing!"
Mar 15, 2012 | Saws
12 inch bosch miter saw blade chnage
I have detailed instructions in the tip section, you might be able to click on my icon to find them. Let me know if you need more assistance
Oct 02, 2011 | Bosch 12" Dual - Bevel Compound Miter Saw...
Having problem get blade off table saw any hints
Unplug the saw, first and foremost.
Then see if your saw arbor has facets for a wrench behind the blade, and if so, try to find a slim wrench that fits there to hold the arbor while you attempt to loosen the arbor nut that holds the blad on. If that doesn't work, take a stick of wood, like a piece about 3/4" x 1 1/4" x 12-16" long, remove the throat plate from around the blade, wedge the stick between the blade teeth and the edge of the throat slot to hold the blade in place firmly, exerting levered force toward the center of the blade to hold it in place, and using the wrench, loosen the arbor nut. Make sure you are attempting to loosen in the correct direction. Depending which side of the blade the nut is on, some nuts are reverse threaded.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 19, 2011 | Craftsman 10" Table Saw
Not cutting a straight line anymore. positive stop is at zero. If I put a 4" board on the saw to cut, I will end up 1/16 to 1/8 inch outside my line at one end. I recently replaced the blade and Im...
you may have not gotten the blade on the arbor correctly, it sound like it is crooked, but if you look at the blade while it is spinning, you should see that. it is most likely the blade being crooked in the arbor, take the blade off and reinstall it.
Mar 23, 2011 | Ryobi 10 In Miter Saw With Laser
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Garden Logo
223 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
