Question about Dishwashers
Top rack is not cleaning well - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 27, 2011
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
Not enough pressure to top rack
PULL WASH ARM OFF OF THE TOP RACK AND SLAP AGAINST YOUR HAND AND SEE IF FOREIGN MATTER IS LODGED IN ANY OF THE SPRAY JETS. CLEAN AND REATTACH
Jul 22, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Dec 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
