Question about Plantronics S12 Headset
When paging over intercom it makes a squealing sound like the mic has been put right up against a speaker. it was fine and then a few hours later it started with this problem. what can I do to fix it?
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
I can't seem to get my microphone to work. Every other sound is working.
You do not say what sort of mic you have - if its a built in laptop mic, a standalone mic or one built into the webcam.
It would also be useful to know what your OS is and what chat program you want to use the mic in
However we can generalise and hopefully put you on the right track
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure your webcam and mic to the Chat program
Aug 31, 2010 | Logitech Webcam
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
VISTA
TEST SPEAKERS
Restart computer
Configure to your chat program
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
Cannot get sound is there a switch to put sound on
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Aug 12, 2010 | Logitech Quickcam Chat Webcam
The vx-1000 installed fine on to my laptop and the image/video side of things works fine but the microphone doesnt seem to be working? any solutions?
Have you made your webcam mic the default mic ?
Vista
TEST SPEAKERS
Restart computer
Configure to chat program
Jun 24, 2010 | Microsoft LifeCam VX-1000 Webcam
No sound
You may have a laptop with a built in mic or headphones with built in mic and webcam with built in mic
You need to set your webcam mic as default
Vista
TEST SPEAKERS
Restart computer
May 23, 2010 | Logitech QuickCam Deluxe for Notebooks
There is no sound
Make sure you have your webcam mic set as default - especially if you have a laptop with a built in mic
TEST SPEAKERS
Restart computer
Apr 20, 2010 | Veo Velocity Connect Webcam
I can't record video with sounds using that A4tech
Make sure your mic is set as default - especially if you have a laptop that already has a built in mic
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Feb 12, 2010 | A4tech PK-635 Webcam
I have been filming wildlife in my garden with a webcam through a 5mt  ext lead. The video works fine,but how can I get live sound from the webcam mic to play live sound through my PC speakers ?
Audio set up Vista
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Aug 16, 2009 | Microsoft LifeCam VX-3000 Web Camera
Plantronics S12 Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
