Question about Gateway Edison Computer Speakers
Wont turn on or play a single sound - Gateway Edison Computer Speakers
  • Gateway Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty graphics card clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 27, 2011
Why wont some of my songs play
Check sound formats supported by your device.
Dec 09, 2014 | Samsung Galaxy Centura SCH-S738C...
Cant get sound from laptop to tv
Just to verify...you've made sure that your headphones jack will play audio in lets say, some headphones, or a set of computer speakers?
However, your T.V. may not recognize audio when using VGA. I say this because if you look at the hook-ups on your T.V., you notice that most sections contain audio and video together, not seperate. If the port is available on your computer, trying using HDMI, the single cord for HDMI carries both sound and video. One last thing you can try with your current set up is find a set of the red and white rca hookups that are independent of any other grouping, in other words excluding the yellow video or any other connections. If you're T.V. wont play the sound in that, then either your headphones jack is messed up or the T.V. just wont recognize it while using VGA.
Nov 21, 2011 | Computers & Internet
Got a crackling sound then it stopped playing.now every time i load a cd i get no disc.
technics wont play cd-r or any copy cd's thats why you get no disc but if this is the case with all cd's then it sounds like you need a new laser unit, the crackling sound is your laser breaking up, there easy to come by on ebay plenty for sale worldwide.
Feb 18, 2011 | Technics RS-TR272 Single Cassette Deck
Tape players wont play the tapes. THey are turning but no sound is coming out. checked all connections and can't figure out whats' happening. Technics model RSTR72. Is it worth fixing or should I get...
you have two buttons B+C USE B to get sound to your speakers if no joy try a simple tape cleaner or anti static tape cleaner this is usually the problem.
Dec 19, 2010 | Technics RS-TR272 Single Cassette Deck
GATEWAY LX SERIS WONT PLAY SOUND ON GAMES OR INTERNET
Here's a link from Microsoft that should help:
http://support.microsoft.com/kb/948481
has a auto fix that could possibly work. Let me know.
Jun 04, 2009 | Computers & Internet
No audio file will play on WMP, no dvd or audio disk will play...
Windows Media Player cannot play several files in the playlist. This might be caused by one or more problems.
To find information about the specific problems, click the Now Playing tab, and then click the blue or red icon next to each file in the List pane.
In some cases, you might encounter this error message if there is a problem with your sound device, such as a sound card or sound controller. For example:
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update or see the sound device manufacturer's Web site.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Boston Acoustic BA735 wont play on my computer
The cable with 2 rings is stereo, a single ring is mono, you have to make sure that you are using the right cable/speaker combo. The speaker output is usually lime green, hope this helps, more info perhaps?
Jan 23, 2009 | Boston Acoustics BA735 Computer Speakers
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Switch bwtn CONT or SINGLE play on Denon's DN-C615
Try this:
1. While holding "Title", Press Stop to enter what Denon calls "presetting" mode.
2. Press Track Search Reverse or Track Search Forward until you get to 20, which is the presetting mode for Single/Continuous Play.
3. Press Play to toggle between Continuous and Single Play.
4. Press Stop to exit Presetting Mode.
Hope this works! I just finished a belabored job without Single Play on this unit. I have been searching for the answer too. I don't have access to the deck to try it, but I think this will do the job.
Dec 23, 2008 | Denon DN-C615 CD Player
42hp84 toshiba plasma
One of the fuse proballly broken in Board Z- sus due to short cicuit inside the single IC (STK 795-***) hidden under a single heat sink. This big IC was hard to remove.Be gentle when removing the 2 flexiboard.................Tarogo
Sep 14, 2008 | Toshiba 42HP84 42 in. Plasma HDTV
Gateway Edison Computer Speakers Logo
188 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
richie46
Raj Patel
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
