Question about Samsung RS2630SH Side by Side Refrigerator
Samsung side by side fridge freezer making a nosie
We had our samsung fridge freezer fixed 18 months ago and told that the nosie it was making was because of the build up of ice at the back of the freezer. It has happened again I have swithched of the fridge freezer, but can I help the defrosting process my self or do I have to wait for it to happen naturally?
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Are you talking about the freezer compartment only?
Leave the door open over night !!
A hair dryer may get you electrocuted!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
HI...I HAVE THE REFRIGERATOR SAMSUNG TWIN COOLING WITH TWO DOORS, DSTH 1, THE FREEZER IS WORKING NORMALY IN - 18 *, BUT OTHER SIDE, NO...I'M PUT IN 3 *, BUT ALL TIME IS 14 * SOMETIMES 15*, 16*...SO , MY...
You need to defrost the fridge side cooling coil behind rear panel on inside of fridge side.
Open with phillips screwdriver and use hot air blow dryer.
This will make fridge cold and water work.
But you will need to purchase new fridge to solve problem. No fix will ever make this work. System is complete garbage.
Dec 26, 2010 | Refrigerators
My samsung fridge 18 months old. the freezer is working so so, however the refridgerator is not working at all any ideas.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side fridge/freezer
BURY IT, NO ONLY JOKING, YOU DO HAVE A DEFROST FAULT, SAMSUNG ARE RENOWNED FOR THESE FAULTS, REMOVE THE BACK AND CHECK THE FOLLOWING, YOU WILL HAVE A DEFROST SENSOR, USUALLY TWO YELLOW WIRES WITH A WHITE BULD ON THE END, PUT A MULTIMETER ACROSS THE END OF THE WIRESES AND HOLD THE WHITE END IN YOUR HAND TIGHT, YOU SHOULD SEE THE RESTANCE CHANGING, IF NOT IT IS FAULTY, TO THE RIGHT OF THE EVAPORATOR YOU WILL SEE BLACK AND RED WIRES CHECK YOU HAVE A CIRCUIT THROUGH THIS ITEM, IT IS A THRMAL FUSE, IF THAT IS OK THEN METER OUT THE TWO HEATERS, IF THEY ARE OK THEN YOU HAVE A POWER MODUE FAULT. REGARDS ADVISOR
Aug 24, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side refrigerator not working
I am somewhat of a fix-it guy and here is my take....I also have the same refridge with other problems, and have done alot of research and discussions with the local repair techs and Factory rep. Here we go: The Samsung models are very prone to problems arising from power fluctuation's that fry the motherboards. One problem may be that the defrost circuit fails and the unit freezes up causing a lack of cooling and loud banging of the compressor. To run a diagnostic of the unit, you need to press both power freeze buttons for 10 seconds beeps will sound and release, the dashes on the display showing if any circuits are bad.(self diagnostic) This is what the service guy will do then come in with the part and replace. With a bad board, the diagnostics reveals no problem and the service agent will just start replacing parts, at your expense! Also the part #'s will show discontinued but they just changed parts #'s.. Be careful, my dealer said all parts were no longer available....he was wrong! Motherboards are a bear, I believe my model has 3!Most techs are not familiar with Samsung and will not be able to correctly diagnose the problems, mine came out and said it! "We do not Know and the factory will not give us any idea what the problem is" We're sorry! That was 3 month ago, and now I have a beautiful yard fixture! a $1400.00 yard fixture!! hope this helps someone..
Aug 07, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
112 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
