Question about Kenmore Dryers
It won't stop running unless i move the dial to "off" -before when I opened the door it would stop
    Master:
    Sergeant:
  • 385 Answers
You have a broken door switch. Hope this helps.
Posted on May 27, 2011
Dryer won't stop running
Oh oh sounds like a bad timer stuck on a certain point, what happens when u move it manually will it shut off then?
Sep 27, 2014 | Kenmore Dryers
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Have plugged in new from box microwave is running when door closed and won't stop unless door open
There is a problem with the door switches or a ground short. I would suggest to return it or have the dealer look at the problem, not a big deal to repair, but does need to be corrected.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 08, 2011 | Microwave Ovens
The drivers-side back door of my 1998 jeep cherokee won't close. The latch has turned too far and won't go back to it's open position so, unless there is some trick you can recommend, it will...
since the door is open,, hold the handle in the open position and try and move the little hook looking latch , it may have just moved into the closed position , if you can move it to the open position, then your home free
Jul 04, 2011 | 1998 Jeep Cherokee
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Dryers Logo
117 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
