Question about Hotpoint TDC32 Electric Dryer
Tdc32 will not heat up - Hotpoint TDC32 Electric Dryer
  • Hotpoint Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 27, 2011
Heats up slightly hotpoint condenser TDC32
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
e76jy
Feb 18, 2010 | Hotpoint TDC32 Electric Dryer
The Hotpoint Aquarius TDC32 dryer appears to keep working but does not heat up
this video will show you how to fix your dryers thermostats
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Nov 01, 2009 | Hotpoint TDC32 Electric Dryer
TDC32 Dryer is running but is not heating up
Hi.
Common fault with these is the two thermostats that fit on the heater at the back of the appliance -- accessable by unscrewing the back cover (MAKE SURE POWER IS DISCONNECTED FIRST!!)
There is a choice of thermostats depending on the serial number of the appliance.
If you need any other assistance please email me on: aardvark.repairs@btinternet.com
Regards
Aardvark Repairs
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
No heat in dryer
if you can see your heating element, use a meter to test for continuity. remove the clips or wires attached to the terminals of the heating element and put the probes of the meter.
the reading should be close to short since it is a heater. maybe 1 to 10 ohms.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Hotpoint TDC32 Electric Dryer
1. see if you have 220 at the plug, the dryer will run on 110 but won't heat.
2. Check the heating coil, it could be broken.
Jul 02, 2008 | Hotpoint TDC32 Electric Dryer
TDC32 making a strange noise when running
sounds like bearings on your tdc32
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 11, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
53 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
