Question about NorStar T7100 Corded Phone
On the display it says Calls for you instead of date and time. How do i get the date and time back please? Thank You
I can't figure out how to show time correctly on both inside / outside screen. it currently displays 17:34 instead of 5:35 please help me with some easy instructions. Thank you, lori.
its under settings and date and time, (or date and time cnat recall exactly) and you can set it from military time *which is what you have now* to standard time Hope this helped!
Mar 27, 2011 | Motorola Mobility RAZR V3
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
When someone calls my phone from another extension in the office how can I get the time stamp to show on my voice mail instead of the persons name?
The date and the callers name should display on the telephone. You cannot display the time stanp, however you can press 7 to listen to the message envelope, which includes the time stamp.
Aug 11, 2010 | NorStar M7208 Corded Phone
Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
DIsplaying date and time on KX-T7731 phone
While the handset is still on the cradle/hook press * or # until the desired view is diplayed.
If this was helpful please rate / vote
Thank you
Jul 21, 2009 | Panasonic KX-T7731 Corded Phone
Time and Date of all the received calls
hello i hope i can help you? may i please ask you when you got the phone did you set the time? on the main phone and then set it on the mobile?
May 05, 2009 | Uniden Cordless Phone
For an ICd-st25 I get UART instead of folder
Thank you for your response. I did finally solve the issue. I basically rebooted the device (removed the batteries). I had to reset the date and time though. The recordings remained intact. Thanks again
Apr 10, 2009 | Sony ICD-ST25 Digital Voice Recorder
Visys time/date display settings will not stay correct - help please!
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Jul 07, 2008 | RCA 25404RE3 Corded Phone
Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time, and the extension information, press the "star" (or asterisk) key while the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
Mar 10, 2008 | Panasonic KX-T7456 Corded Phone
NorStar T7100 Corded Phone Logo
24 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
