Question about Panasonic TH-50PV30 50 in. Plasma Television
Hi Have a panosonic Th-50pv30 tv, since the digital change over it has started on bbc1 to have the information bar coming on to the screen every few minutes [ like it has dropped it's signal]. Some times when on bbc2 it will change over to bbc1. Have taken batteries out of remote , but this still happens. Have re - set tv to factory settings but has made no difference. It only happens on these channels all others are ok.
5 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Panasonic TH-50PV30
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Dec 22, 2005
  • 8457 Answers
SOURCE: restore factory setting
U can't.Buy an original remote.Try Website 1-800-Remotes Factory Original.
Posted on Dec 30, 2009
SOURCE: Toshiba 19DV500 b will only
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
Posted on Feb 09, 2011
jdvillanueva
  • 2098 Answers
SOURCE: I have a Panasonic TH-42PZ80U.
Hi marc_uhrey,
Can you turn off the unit with its power switch in the front panel of the tv or not?
Jdvillanueva
Posted on Mar 09, 2011
42 " panosonic plasma model th-42px6ou keeps
There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
Oct 16, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-42PX60U Turns On/Off by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 30, 2017 | Panasonic TH-50PV30 50 in. Plasma...
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
Black line in middle of panasonic plasma screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Durabrand TV/DVD dct1481
The blue screen is fairly common and is displayed when inadequate signal is present.
In other words, 'no reception.'
The weak BBC1 signal is kind of a confirmation of your poor signal strength.
Aug 20, 2008 | Durabrand DWT1905 TV
Panasonic TH-50PV30
Make sure the power supply cable is tightly plug-in, the one in the back of the TV. This fixed my problem.
Jun 06, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30
Dec 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30 50 in. Plasma Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
