Question about Dishwashers
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
Posted on Aug 07, 2012
  • Tommy tommy
    Tommy tommy Feb 02, 2014
    Had the same problem. This trick solved it :)
  • Leyla Pedersen
    Leyla Pedersen Sep 23, 2014
    This works!! Thank u very much. And I just handwashed a full load before trying this...
5 Suggested Answers
  • 5 Answers
SOURCE: zt685 built-in dishwasher. power light illlluminated
door not closing properly can you hear door click? problem with door switch
Posted on Jun 25, 2008
  • 157 Answers
SOURCE: flashing lights
Heater needs replacing.
Posted on Dec 31, 2008
  • 3230 Answers
SOURCE: dishwasher wont start
check that following -
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
good luck.....
Posted on Mar 28, 2009
SOURCE: My IKEA Renlig DWH B40 stopped runningand alarm
I have the same problem. Did you solve it?
Posted on Mar 28, 2010
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Renlig dw45 the washing machine keeps trying to drain even though it is empty please help
Yup. I have an IKEA Renlig DW45 and this cured the problem (the dishwasher would not stop draining).
Thank you so much for taking the time to detail it here for us.
Jan 20, 2014 | Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
When switched on the pumpbutton stays red and the program selection does not want to move, one program remains blinking green. When door is closed pump starts running non stop. Cannot find any reset button
Thanks to a manual that was sent to me I understould I had to press the button P for a long time, that resets the machine. Thanks for your service! Carolijn
Nov 23, 2009 | Candy DFI Plan Built-In Dishwasher
Electrolux dishwasher all lights blinking and wont turn on push start button either all lights flash or normal light stays onĀ  either case the dishwasher wont run a cycle
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Apr 23, 2009 | Electrolux 24 in. EDW5500DSS Stainless...
ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Sep 13, 2008 | Dishwashers
Dishwashers Logo
2,456 people viewed this question
Top Dishwashers Experts
Owen Barnes
