Question about HP PSC 1610v All-in-One Printer
Ok my hp psc 1610 says its align and i pressed ok then after 2 seconds it says check color cartridge and the it said check right cartridge and (i refilled this at costco it was working fin a week ago and now its not working)
    Sergeant:
  • 246 Answers
Try to resetter your printer
Posted on May 27, 2011
Chsnge ink cartridge
Hi there!
Here's what you can do to change the Printer cartridges.
1. Make sure that the printer is turned on. Turn it on if it's not.
2. Open the printer cover, then wait until the carriage is idle.
3. You will see the Tri-color & the Black cartridge. The tri color cartridge is the green one which is on the left and the Black is the one on the right.
4. Press down the Cartridge you want to replace you will notice that it will be released from the cartridge holder. Once it's loose slide the cartridge out.
5. Make sure that the correct Genuine Hp Cartridge is what you have. For your printer HP PSC 1610, HP 94 will be for the black and HP 95 is for the tri color.
6. Open the cartridge package. Remove the protective tape. Make sure that you do not touck the copper colored contact and nozzles.
7. Hold the print cartridge with the sticker facing up and the copper colored contacts facing the printer and slide it into the cartridge.
8. Use your thumb to push the cartridge all the way in. You may need a little force to make sure that the cartridge has been installed securely.
9. Once installed close the cartridge cover. Make a copy to test.
Hope this helps!
Jun 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
Printer won't accept new color cartridge. Keeps saying "Check your color cartridge." When we do and press okay it sends the same message
We need to check few things here and for that we need a test page
Make sure your printer is ON and unplug the power cord
Now Press and Hold OK and Cancel button at the same time and while holding them plug in the power cord
Once the printer turns on it will say "Derive Clear"
Now press the Right arrow until you see " Service Menu"
Hit Ok here
Now look for print 10 tap test
Hit ok
It will print a test page
Now look at Line 66
And let me know the STAT value it can be 0, 1 or 2
0- Cartridge fine - problem with printer
1- Problem with cartrdige
2- Check the tape on the cartridge
Jan 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
Black re-mfg for psc 1610 prints unreadable
your black print cartridges has been dried, these need to replace.
Aug 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Remove and check right cartridge (black ink)
I have discovered how to perform a full reset of the HP PSC 1610, which clears all the internal memory, thereby fixing the "remove and check right cartridge" problem.
To perform a full reset of the HP PSC 1610:
1. Unplug the power cord.
2. Press and hold the OK and CANCEL buttons on the front panel keypad.
3. While still holding the buttons, plug the power cord back in. Continue to hold the buttons for two seconds, and then release them.
4. After a few seconds, the screen will display the message “Deriv Clear” confirming that the reset is done.
I have discovered that the HP PSC 1610 all-in-one printer has a hidden diagnostic mode, which lets you do several interesting things.
To enter the hidden diagnostic mode of the HP PSC 1610:
1. tap both arrow keys simultaneously.
2. tap the left arrow key.
3. tap the OK key.
4. At this point, you have a choice to make. If you want to enter the "Service" menu, tap the left arrow key. If, on the other hand, you want to get into the "Underware" menu, tap the right arrow key.
There is a menu option in the "Underware" menu called "printer-mech button tap", from which you can initiate any of HP's "tap tests," so called because, on the early HP printers whose onboard user interface was limited to two physical buttons, you would tell the printer which diagnostic test you wanted it to perform by holding down one of the buttons while tapping the other button a certain number of times. In the HP literature, the various diagnostic tests that the printer can do are named according to the number of button taps required to initiate the test. Hence, HP might refer to "tap test #6", "tap test #9", and so forth.
I am not sure what all of the various tap tests do, but I would imagine there is probably a tap test that resets the internal counter responsible for making the printer reject the cartridges.
Dec 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Print cartridges
Is it a genuine new HP cartridge and also not an expired date? Also may need a new printhead.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 31, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP PSC 1610v All-in-One Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
