Question about Kenmore Dishwashers
Kenmore 665.15772/etc. built-in dishwasher. Controls are acting funny. "Lock" light comes on unexpectedly. Cannot initiate wash cycle, even after turning off "lock" light. Other lights appear erratically when trying to push "No-heat dry" etc. I suspect problem with control module. Please advise.
  • 20 Answers
SOURCE: dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Posted on Jan 20, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 523 Answers
SOURCE: Dishwasher will not operate. Kenmore 665
control panel
Posted on Jun 01, 2010
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Kenmore 13742k603 wash cycle lights come on but wash will not light and start
see the diagram attached:
1) test the switch door for defective or open, if there are wrong the relais will not close and NOT start the motor.2) Timer test, 3) c.breaker from you home or blown fuse 4) wires defective loose, burn, or break
Jun 18, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
My kenmore ultra wash instaled dishwasher wont work. The "lock on" light is illuminated and when i press any button the lock on light just flashes 3 times. i tried pressing buttons, holding the...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Sep 16, 2011 | Kenmore 15129 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
My dishwasher won"t wash. Help me, PLEASE???
Try pushing and holding the "Air Dry" button for at least 4 seconds. This should turn the control lock off.
Sep 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
