Question about Baumatic Refrigerators
I have a built in wine cooler BWC300SSV2 and it will not chill the tempriture is 23 deg and i can only get it to program between zero and 8 degrees and it is constantly at the 23 degrees and wont chill.
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
The location of the sensor needs to be higher but my yellow wire would only pull out a couple of inches.
Turn off power to unit and remove front panel. Two screws near top/sides. Top of panel pulls out (unplug wire connector to indicator lights) and lifts off bottom tangs. Now you will see a coil of yellow wire inside unit. Remove the wire tie and you'll have enough yellow wire to locate the sensor well above the heater.
Posted on Dec 31, 2007
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
SOURCE: sylvania table top wine cooler
go back where you bought it...buy another one and bring back the one thats flashing,get your refund and walk home with a new cooler
Posted on Jul 03, 2009
SOURCE: Avanti Wine cooler Model #
I had this issue and it had all to do with ventilation. If the fridge is in too tight of a space without any type of air space this will be the result. I was able to cut into the cabinet behind the fridge and put a 18" x 18" grate that allowed air to move. Problem solved!
Posted on Jul 22, 2009
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
Jun 19, 2012 | Refrigerators
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
The power seems to be OK ,but the wine cooler is no longer chilling The temperature registers over 80 degrees . We think the compressor is gone. The wine bottle capacity is 30 bottles. Is there in home...
Mcintyre Tv & Appliances
Rr #2, 9622 Dalton Rd.
Grand Bend, ON, N0M 1L0
Phone: 519-238-8270 Appliance Doctor
82 Victoria St E
Wingham, ON, N0G 2W0
Phone: 519 357 4668 Stew'S Rec Vee Service Centre Inc
County Raod 12e G/D
Kippen, ON, N0M 2E0
Phone: 519-263-6058 https://www.danby.com/locator.php?type=dealers It doesn't state if there is in home service or not. But those are the three service locations that are listed in your area.
Jun 11, 2011 | Danby DWC283BLS Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
The wine cooler doesn't seem to be cooling light goes on when you open door so pretty sure it has electricity to it?
Can you hear it running? If there is a question, leave the door open and remain there until you hear it start. This may take up to 15 minutes.
What do you have the control on? Wine coolers ar not refrigerators. (White) wine typically served at cellar temp (around 50 to 55 degrees. My friend, please don't tell me you are chilling quality Reds! You are killing them.
Thanks for your interest in FixYa.com
Jan 29, 2011 | GE Monogram ZDWT240PBS Wine Cooler
On two recent occasions, my unit has chilled the wines down to about 36 deg.F. It has otherwise run fine for about two years, maintaining about 57 deg. F, consistently. Any idea what would cause such...
wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
Dec 05, 2009 | Transtherm Ermitage Wine Cooler
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
Refrigerators Logo
101 people viewed this question
Top Baumatic Refrigerators Experts
Sal De GO PATS
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
