How do i reset service code F1-46 for my sharp mx5500n copier
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 30 Answers
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Posted on Feb 25, 2009
  • 67 Answers
SOURCE: Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Posted on Apr 21, 2009
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
What is Code: H5-01 on the sharp mx 2300 copier
You need a service reset.This is a fuser problem .clr and star and hash and star fusing reset
Oct 27, 2009 | Sharp MX-2300N Color Copier
How do you reset the error message : maintenance requred, call a service technician?
You call a Sharp Service Technician and have them reset it. That code cannot be reset by a user.
Oct 08, 2009 | Sharp AR-168D Black and White Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Jan 16, 2009 | Toshiba e-Studio162D Copier
H-3 error code in a Sharp ARC260m
The analog Sharp copiers used the crop code (clear, repeat, zero, pause).  Once the digital models came out the rules changed.  Sim 14 was for the analog copiers as well.
A good resource to get the answers you need is copytechnet.com.  They have Sharp copier technicians on there who can help you with the problem.  Unfortunately I only work on the low end Sharp models (for their product line).  The service codes are different on that machine. Copytechnet is a free service and they only deal with copiers.
Oct 03, 2008 | Office Equipment & Supplies
Sharp AL-1540cs reset for drum
Its supposed to reset itself without a service code. If it isn't let me know.
Apr 17, 2008 | Sharp AL 1215 Black and White Copier
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
35 people viewed this question
k24674
