Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
How do i change the primary mowing belt? Is the a way to release the tension on it so I can actually fit the belt on?
    President:
  • Husqvarna Master
  • 1,545 Answers
Here is your 3.42MB online manual. You can find the diagram with instructions for this procedure in the manual on page(s) 18-21.
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_YTH21K46_532442472.pdf
Posted on May 27, 2011
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Timing belt
Did you replace the belt? If so, you may have the wrong one... if no, your belt may be worn out.... make SURE you have the correct tensioner for you application!! ,, sometimes they actually make a defective tensioner...
Nov 06, 2017 | Peugeot Cars & Trucks
How to change serpentine belt 1998 plymouth voyager 3.0 engine
draw a diagram of how the belt is on now
there is tension pulley which fits a 3/8 ratchet
release the tension on the belt and remove it
install the new belt using the diagram you drew
Nov 11, 2013 | Cars & Trucks
How do i change without taking off motor mount?
Follow run of the belt, there is an idler/tensioner some are spring loaded other`s are manual adjust release the belt tension ,slide off belt.Reverse procedure to fit new one......
Jan 06, 2013 | 1998 Buick Riviera
How do I change timing belt on ford fiesta 2000 Diesel engine
according to picture belt already off
rotate crank to timing mark and position injector pump mark to dot and camshaft pully to dot loosen tensioner and fit belt being careful not to shift marks. Fit belt and release tensioner. rotate engine clockwise a couple of turnsand check if dots still line up. readjust tensionor to belt and refit covors etc...
Nov 16, 2012 | Cars & Trucks
How simple is it to change a alternator belt on subaru svx?
  1. Removing the Serpentine Belt
    • 1 Park your Subaru on a level surface and open the hood.
    • 2 Disconnect the ground (black) battery cable using a wrench. This will prevent the cooling fan from activating.
    • 3 Locate the serpentine belt routing diagram in your engine compartment and compare it to the actual routing of the installed belt. Make sure the routing on the label matches the actual routing. If they do not match or there is no label, note the actual routing on a piece of paper for later reference.
    • 4 Locate the belt tensioner pulley on your Subaru model. If the tensioner is equipped with a squared hole, use a large breaker bar with a 1/2-inch (13 mm) drive. Otherwise, use a ratchet and socket of the proper size on the tensioner pulley center bolt.
    • 5 Rotate the tensioner pulley away from the belt to release the belt tension.
    • 6 Pull the belt off of one of the pulleys and slowly release the tensioner pulley back into position. Do not let the tensioner pulley snap back or you may damage an internal component.
    • 7 Finish removing the serpentine belt from the rest of the pulleys and the engine compartment.
    Installing the New Serpentine Belt
    • 1 Match the old belt to the new one and make sure they are of the same length and configuration. It is normal for the new belt to be slightly shorter since the old one has been stretched through use.
    • 2 Route the new serpentine belt through all of the pulleys except the tensioner pulley. Use the diagram on the engine compartment or your notes, as a reference, to properly route the belt.
    • 3 Insert the large breaker bar into the square hole or the ratchet and socket into the tensioner pulley center bolt.
    • 4 Rotate the tensioner pulley in the same direction you did to release the belt tension.
    • 5 Slide the serpentine belt onto the tensioner pulley.
    • 6 Release the tensioner pulley back into position.
    • 7 Look at all the pulleys and make sure the serpentine belt is properly seated on each one. Otherwise, release the belt tension and adjust the belt.
    • 8 Connect the ground (black) battery cable using the wrench.
Oct 18, 2011 | 1992 Subaru SVX
How do you change a 1998 regency serpentine belt
look under your hood for the information tag on your serp belts routing. It will show you where the idler/tensioner is at. Use the appropriate size socket to fit the nut on the tensioner and push or pull it to loosen the belt. Slide it off and release the tensioner. Then reroute the new belt and again, push or pull the tensioner to reinstall the belt on it.
Jan 04, 2011 | 1998 Oldsmobile Regency
How to change an alternator belt for a 96 chevy cavelier
go to http://www.mvreader.com/multiview/dayco/index.php?bgInterchange=1&l=n
They have diagrams for the routing of the new belt..
As for actually doing it.
1. you need to release the tension idler to release belt. This can be done with a simple ratchet, its spring loaded so it takes some muscle.
fit the new belt in the correct routing from the website i gave you and there you go.
Sep 06, 2009 | 1996 Chevrolet Cavalier
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
How do you change serpentine belt on a 2003 ford escape xlt 3.0L engine
Rotate the accessory drive belt tensioner (5)clockwise and remove the accessory drive belt.
Mar 05, 2009 | 2003 Ford Escape
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
316 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
