Question about Frigidaire FAH125N2T Air Conditioner
This unit turns on, but does not cool. i need the measurements for this unit so i could replace it.
Magic Chef Model: mcwbc77dzc Not cooling. Need help identifying a part.
try disconnecting thermistor if cools replace if no bad cooling unit
Apr 09, 2018 | Magic Chef Refrigerators
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
York heat pump running but not heating.. defrost board and sensor replaced..but still no heat.
The outdoor unit is running? Measure temp split between return and supply and see if any difference. Does it cool ok? What is the temp split in cooling?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 27, 2018 | Heating & Cooling
What is the measurement of ton on ac units.
Ton is a measure of cooling only when buildings were cooled by ice and how many tons of ice they would use in 24 hours.
British Thermal Units (BTU's) is also a measure of cooling as well as heating in 1 hour.
1 ton equals 12,000 BTU/hr and 1 watt equals to 3.41214 BTU/hr.
Jun 15, 2015 | Heating & Cooling
I have a 6 yr old lennox merit 10acc system and the compressor doesn't seem to be running as there is no cold air and line out of compressor is not cold/sweating like my 2nd (good) unit.
you cant check capacitor with power on it nor using volt setting.need micro ferred setting on meter and check with power off and wires removed. leads go as follow for fan one lead on "C" and one on fan. For compressor one lead on Common and one on HERM. Also be sure voltage on capacitor is correct 360V or 440V. 440V will work for either. Also double check micro ferred requierment on motor and compressor. If its been replaced before may have been replaced with incorrect size. It happens.
Aug 23, 2012 | Heating & Cooling
HI I ahve a MSH-07NV airconditioner. It has had this problem before. I called a repair man and he said it was operator error. It turns on remotely then the fan stops and it goes down to 1 light that flicks...
As you don't mention the error code. There are 2 reasons for your unit as hereunder.
Check your indoor room temp sensor and coil sensor
Indoor unit return air sensor fault. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Jan 07, 2011 | Mitsubishi Heating & Cooling
Replacement for Emerson Quiet Kool 12jw42k
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
May 28, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
I have a robinair cool tech 700 not recovering
You Need to replace your unit compressor.Because may be you did not change spin-on filter after recovering 150 LBS of refrigerant.
May 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
Frigidaire FAH125N2T Air Conditioner Logo
26 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
