Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
When ever I let go the brake the engine turn off. I step on the brake the engine keep running without shout off. As soon as I let go the brake the engine shout off so my question is what is wrong and what I need to fix the problem?
  • 608 Answers
Hi, the seat switch is not recognizing that you are sitting on the seat. The switch or wiring to it is faulty. Hope this helps, regards Phil.
Posted on May 28, 2011
When i use the left turn signal alone it works great but as soon as i step on the brake it quits flashing
you have bad connections at the bulbs or at the harness to the bulb assembly.
Mar 05, 2013 | Cars & Trucks
Chevy blazer brake pedal going to the floor when engine is running
has to be air,try bleeding without the brake pedal,just open
the bleeders and let gravity run the fluid out,takes awhile but works.
(master cyl.cover off )
Dec 25, 2012 | 1999 Chevrolet Blazer
Did complete brake job on 1997 Ford Escort wagon no abs rear shoes, drums, lines, wheel cylinders,even changed the block at the rear were the lines go in & out of. Front lines hoses pads, caliplers...
is brake pedal hard to push down without engine running ,if so proceed to step two and thats to start engine and then push on brake and if pedal softer to push then the servo is working ,now if excessive pedal travel with engine running then remove the rear drums ,make sure the outside lip is cleaned out and then adjust the brake shoes manually till they rub when you turn the drum ,this will cure it but remember that it has to bed in of course new pads brake disks ,new shoes and drums it has to bed in so give it a chance .
Aug 24, 2011 | 1997 Ford Escort
How to bleed rear brakes
  1. Remove the top of the master cylinder reservoir.
  2. Using a turkey baster, **** out as much of the old dark inky fluid as you can.
  3. Clean any sediment out of the reservoir with a clean, lint-free rag. (Do not spill any brake fluid on any painted surfaces, it will remove the paint immediately.)
  4. Fill the master cylinder with clean brake fluid.
  5. Replace the top of the master cylinder reservoir.
  6. Pump the brake pedal several times (15 or more).
  7. Using a box wrench that fits the bleeder bolt, loosen the bleeder valves, but leave them closed. (A little penetrating oil drizzled on the bolts the day before will help to loosen them).
  8. Using a piece of clear plastic tubing (aquarium tubing works fine), push one end of the tube over the brake bleeder bolt.
  9. Put the other end of the tube into a small, clear bottle with an inch or two of clean brake fluid in it. (This will keep air from being sucked back into the brake cylinder.)
  10. Put a piece of 1 x 4 lumber or some other "spacer" under the brake pedal to prevent the pedal from traveling too close to the floor.
  11. Remove the top of the master cylinder reservoir.
  12. Top off the master cylinder reservoir with fresh fluid.
  13. Replace the top of the master cylinder reservoir.
  14. Have your helper sit in the driver's seat and slowly depresses the brake pedal with an even force and hold it down. The helper should shout "down" when the pedal is down as far as it will go.
  15. 15Starting with the rear passenger wheel (back right for righthand drive cars), turn the bleeder bolt to the left one quarter-turn. Old fluid and air will go down the tubing into the bottle. When the fluid stops, close the bleeder valve.
  16. Shout "up" to your helper, who at this point should remove his foot from the pedal allowing it to move up.
  17. Repeat this process until new, clear fluid comes from the bleeder tube. (After every five (5) times the brake pedal is depressed, top off the master cylinder reservoir with fresh fluid. Never let the reservoir get too low, or air will be sucked into the master cylinder.)
  18. Tighten the bleeder bolt.
  19. Repeat steps 14 to 17 on the left rear wheel.
  20. Repeat steps 14 to 17 on the right front wheel.
  21. Repeat steps 14 to 17 on the left front wheel.
Jun 23, 2011 | Harley Davidson Springbok Harley-davidson...
How can i bleed the brakes in my 91 skylark?
on the back side of calipers you will see a small bleed fitting -- attach a small 1/4 inch CLEAR hose to this fitting and run it into a catch bottle ( of some kind ). top off the brake fluid reservoir with fluid. now you will need a helper to sit in the drivers seat and ready your commands. use a small wrench and turn the bleed fitting counter-clockwise ( only about 1/2 turn ) -- have your helper press down the brake pedal and hold it to the floor,, and with the brake pedal to the floor you need to close the bleeder,, as soon as it is closed - have your helper let up off the brake pedal,, now open the bleeder again and have them push and hold the pedal to the floor again,, close the bleeder -- have them release the pedal,,, continue this process until you see no air bubbles flowing out the bleeder ( thru the clear hose ). keep the reservoir topped off with fresh brake fluid ( do not let it run dry or you will have to bleed the lines again ). repeat these steps for all calipers on the car and you will be good to go. --- also keep in mind that as soon as all the air is bled from the system -- when you pump the brakes, the pedal should get very hard and stiff,, if it goes to the floor after you have bled the system - then you still have air in one of the lines and you will need to continue bleeding.
c...
Jan 24, 2011 | 1991 Buick Skylark
1994 Pontiac Grand Am Its sat about 2 months now. I went out to start it. It was dead. So I jumped it. Well I got it started and the check engine light and abs light was on. Well I put my foot underneath...
If the battery is bad and not holding a charge, every time you push on the brake's. The break lights come on and puts a load on the electrical system and if the voltage drops below 10.5 volts, the ECM will shut down fuel injector and ignition system. The other thing to is that the fuel pressure may be dropping due to the electric fuel pump not getting enough volts every time you put on the brakes. You cold always try keeping the jumper cables connected to make sure it's the voltage drop that is causing the engine to stall. Keep me posted, be glad to help you get your car running 1005 again soon.
Nov 07, 2009 | Pontiac Grand Am Cars & Trucks
My car dies when it get warm?
sounds like a your tie rod ends or ball joints are bad. as far as it turning off in gear means that the fuel injection is screwed up which means its a gas problem which is a intake problem with wrong fuel mixture or even a vacuum leak.
Jul 26, 2009 | 1994 Pontiac Grand Am
Car runs rough when it does run. then in about 5 miles it just dies no power at all? the battery is new so is alt. new plugs and wires ? it just dies and needs a jump. soon as its off it wont start again...
Have your mass air flow sensor cleaned/serviced., then your catylictic coverter.you can chk but takes two people. one at the tailpe and the other at the key. The moment the engine is turned of, the exhaust shout stop.Using a tissue see if the exhaust continues bet in a drifting manner. Note any odor of rotten egg or sulphur smells. Listen for ant wheezing coming from the tail pipe while the engine is running. This is rhe more probable cause. Good luck -Ned
Jun 15, 2009 | 1999 Nissan Maxima
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
