Question about Ariens Lawn Mower Ball Bearing Replaces ARIENS 54073
Heavy blade vibration while running - Ariens Lawn Mower Ball Bearing Replaces ARIENS 54073
  • 43,501 Answers
The blades are out of balance...
You will need to take them off and regrind them to get them balanced...if you sharpen them or even if you hit something like a rock it can knock them out of balance...
Place a small nail through the hole and hold them up...both sides of the blade should hang level...if one side is heavier it will go down and the light side will go up... grind more off of the heavy side...
heatman101
Posted on May 27, 2011
Heavy vibration on Silver eagle dixle chopper. Blades are balanced.
bearings are bad or belt is damaged if the blades are balanced.
Jun 07, 2017 | Garden
I have a execu indoor helicopter. the problem is the one roter does not want to spin fast enough. and there is alot of heavy vibration .
The blade could have been damaged in an impact or the balance mechanism has dropped a weight. Check for damage
Jul 25, 2014 | Toys
Audi a4 windscreen wipers juddering vibrating
The problem you have comes from wiper blades causing friction in light rain conditions and can be cured by cleaning the rubber that contacts your windscreen with a rubber cleaner/conditioner or you can use spray silicone on the blades.
Jan 18, 2013 | 2004 Audi A4
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have this vibrations around my fan clutch and some time it sounds like something is clicking or tapping.
The clicking is generally caused by a flat roller bearing. If the sound seems to be from the fan clutch you can grab the fan blades and see if the bearing is worn by rocking the blade by pulling it towards you and rockng it away from you
Another way to see if its bad is to use a solid pole something like a broom handle. Place one end of the handle on the accessory that runs off the serpentine belt such as the alternator and place your ear on the other end of the handle. As the engine runs you can hear a bearing making noise revolving as it move. If a bearing is bad the noise will be much louder and have a heavy grinding noise
Sep 28, 2011 | 2003 Chevrolet TrailBlazer
Vibration when blade on no vibration when blade off
you have a bad blade or the flanges are worn causing a runout of the blade, if you can watch the blade as it slows down you can see the wobble,
Jul 29, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Heavy vibration and noise
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Dec 28, 2008 | Omega 1000 Juice Extractor
Lg 18000 remote with heater
your fan blade hit something and i think one of the blade got damaged and somehow it is no longer balance and makes a lot of vibrations.
have you read in the instruction manual to remove some kind of a shipping support before running the unit?
im just curious what hit your blade. it could be the shipping support for the compressor.
tnx 4 using fixya,
drcool
Sep 14, 2008 | LG BG8000ER Air Conditioner
Ariens Lawn Mower Ball Bearing Replaces ARIENS 54073 Logo
101 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
