Question about Dual Cameras
The Zoom Ring has come loose. How do I retighten the ring. It looks like there are threads up on the barrel to keep the Zoom Ring in place. Can you explain how this is done? Or send me the instruction to do so?
  • curtis553 May 30, 2011
    ftw1952,
    Sorry to say. It took longer than I expected to receive a response. Yes, you are correct if you were wanting to get to the Focusing Mechanism. I was wanting to reattach the Zoom Ring that came loose. Now that I took a chance on correcting this myself. It is now done.
    To do what I was afraid to try. Is one has to remove the camera mount retainer and the Macro Adjuster and this allows you to access the threaded locking ring that holds the Zoom Ring in place.
    Note 1: The tricky part is to remember how it goes back together.
    Note 2: I used my iPhone to take pictures while I dismantled the lens. It help a great deal when putting the lens back together.
    I do not feel that this response was correct concerning my question. I know that this only cost $6.00. But to some this is a fortune. I would like to have a refund for this instance. I will send my response on to FixYa as well.
    Thank you anyway for your try!
    Curtis553
  • 10,319 Answers
The rubberized covering would need to come off to gain access to the two screws that hold the guides to the zooming function tightly on. It is a difficult task to do although it the covering will stretch out of shape if done without slow caregoing about it. Simply remove the covering by gently prying up all the way around and pull at the same time. Nothing can be added to give you an easier way to do this such as oil, soap, etc foe it will get inside the lens housing. Once it is off you can see the hold down screws for the zoom barrel
Posted on May 30, 2011
How to reassemble 50 mm pentax slr lens
The problem usually comes about when the focussing ring comes loose. Step 1 remove the 1.front round name ring 2. filter ring. this will expose three screws that hole the focus ring in place. reset the focussing to infinity on your viewfinder then set the ring to the infinity mark and retighten. If the helicoid has come apart then take the mount ring out, aperture ring out, and remove the two focus guides. turn the core out, set the fine thread back until it is almost against the ring directly behind it. make sure that it has at least one and one half turns. then engage the helicoid back. refit the focussing core into the lens and refit the two guides.reassemble the lens and revert to step one to reset the lens.
Oct 05, 2013 | Pentax K1000 35mm SLR Camera
Hi, i have the Sigma 70-200mm for Canon EF and the manual focus don't work. The HSM works fine and focuses perfect, but if you choose MF, you can't rotate the focus-ring. Many greetings from Germany! Kai
Hi, not sure if you still have this issue. I have just decided to look into it again, as I had a lot of focus problems with my Sigma 70-200mm HSM lens. Since there is no Sigma support here in Beijing, I took a look - and fixed it.
Here is what I did: On the front of the lens barrel is the rubberised focus ring. This can be removed (gently ply it away from the barrel by sticking a flat bit (or plastic letter opener) between the barrel and the rubber grip. It will come not entirely loose, so you need to work your way around the lens. Keep doing that until you moved it about half way forward. At this point two fixing screws become accessible on the barrel below.
In my case, one of the screws had come loose and that blocked the focus ring from turning, as the screw was blocking rotation in the access hole on the barrel.
Hope this helps others. Simple to fix, if you know how.
Nov 26, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Tamron 17-50 loose ZOOM ring (not Focus ring or Front Element)
the same thing just happened to me like 3 days ago. The zoom ring was kinda sticky and then all of a sudden it just spins around and doesnt extend the barrel at all.
Nov 16, 2009 | Cameras
Canon A720IS loose lens
the way its made you cannot take it apart and have it to work correctly so if you call the factory and they should help replce it or they should replace it if its in warrenty or you might have to pay a repair fee sorry hope this was helpful:)
Nov 16, 2009 | Video Game Consoles & Games
Zoom error appears in viewfinder on FinePix S7000 and cannot take photos.. Please help
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Oct 02, 2009 | Fuji FinePix S7000 Digital Camera
Honda Accord 2002 Cigarette Ligher socket loose
Some of the cigarette lighters have a threaded outer shell that keeps them in place. If you can follow the wires back from the socket there might be a empty "shell" hanging on the wire. Guide it back up to the socket, and while holding the socket in place tighten the shell around the socket.
Jan 08, 2009 | 2002 Honda Accord
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
My question is about a Quantaray 75mm-300mm
Slide a piece of paper partway under the ring (make sure you leave enough hanging out so you can remove it later) and see if that tightens the action some.
Another low-tech approach is to push the ring to expose the inner barrel, then attack one or more pieces of Scotch tape or masking tape.
Jul 30, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
The zoom ring has stucked
The fact that you have been in older lenses make this a bit easier. These newer ones are modular.
The circuitry is the most sensitive part, make notes or take a picture of how all the connections are made. Most of the flexible connections are fairly straight forward.
Once you get the lens down to removing the outer barrels, you'll likely find that a zoom guide or two have come undone or are damaged. These are small nylon rollers with a fat screw in the center.
Being that it is winter, static may be a problem. Don't zap the brains of the lens
I'll keep an eye on my email notices, I cannot do live chat since I use a Macintosh most of the time.
Kevin
Feb 21, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Olympus E-510 70-300zukio
The markings on the lens barrel are for macro mode purposes. When the zoom ring is set for 300mm that is the distance you are shooting at. It will zoom the barrel all the way out to 300mm if it needs to to help to obtain focus on the subject.
Hope this clears things up for you.
Feb 19, 2008 | Olympus EVOLT E-500 Digital Camera
Cameras Logo
205 people viewed this question
Top Dual Cameras Experts
Are you a Dual Camera Expert? Answer questions, earn points and help others
