Question about Whirlpool Refrigerators
I have a whirlpool gold model# GX2FHDXVQ02 S/N# K02263328 and the freezer section needs to be defrosted. How do i defrost it?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 27, 2011
Whirlpool gold french door bottom freezer ices up and causes fridge to run warm. I have taken it apart and defrosted several times. Fan works, drain is not clogged. What could be the cause of this?
The self defrost function is not working. Depending on the age and model you have a heater, bi-metal defrost thermostat.....and either an electronic control or defrost timer. One of these parts has failed. Need a model number to tell you more.
Apr 30, 2017 | Whirlpool Refrigerators
My Whirlpool Gold Series Fridge is not cold in Fridge part, but is still working in freezer part. What might the remedy be?
Could be a few things. One could be a bad evaporator fan motor in the freezer section. The fan motor will only come on when the light switch is closed so make sure you hold down the light switch when you check it. Could be a defrost timer or defrost bimetal. You will know because you will have ice buildup on the back wall inside the freezer. Also could be icebuildup in the return air duct. They are located under the drawers in the refrigerator.
Oct 19, 2014 | Whirlpool Refrigerators
Freezer issues with Conquest
freezer is supposed to defrost? need more info..
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I hear dripping from the freezer section
defrost element is on may need defrost timer
Oct 08, 2009 | Whirlpool GC5SHEXNS Side by Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer frosts up and then the refer doesn't get cold air. I have completely defrosted it twice. Model # ED25DSXDN03
You have either a bad defrost heater,defrost thermostat or defrost timer.
The defrost timer is located in the control panel box in the fresh food section. The heater and thermostat are in the freezer section behind the rear panel.
On this brand it is usually the defrost timer.
Jun 26, 2009 | Whirlpool Refrigerators
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer defrosting
you have a defrosting issue for sure, you neeed to unthaw the freezer coil first and then find out if the defrost heater the defrost timer or the defrost bimetal is the issue one of these three parts is bad
Apr 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
271 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
