Question about Lexmark X75 All-In-One InkJet Printer
I am having problems with my lexmark x 75. I need to print important documnets. Every time I pull them up and go to file and print nothing happens. This has been going on for the past two days. I have checked to make sure everything is hooked up correctly. Please help me with this issue.
  • Lexmark Master
  • 817 Answers
You need to first empty the print queue. Go to printers and highlight the X75. Go to file,cancel all docs and let it delete all the jobs.
Now unplug the usb cable from the pc and plug it into another usb socket. the computer should redetect the printer and produce a COPY1 in Printers. make this the default printer and all should work of as long as you already installed the driver correctly.
Posted on May 27, 2011
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
I am trying to print important documnets. Every time I go to FILE and PRINT nothing happends. I have checked all cords to make sure its hooked up properly. However the problem is still here. I have click...
Make sure the Lexmark X75 driver software is installed on your computer. You can download and install the Lexmark X75 driver by visiting the Lexmark website at http://bit.ly/iSpJjv.
It could be a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
May 27, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
HP 4700 not printing excel files correctly
Only solution I've found is to print to pdf, then send the pdf to the 4700. pdf995 works quick & cheap
Jan 19, 2009 | HP LaserJet 4700 Printer
Lexmark x2500 err msg: UNABLE TO CONNECT
What you will see
When trying to print, you get a communication error; the device is correctly detected in the Device Manager, the firewall is not blocking any files and you can scan using the All-In-One Printer.
Explanation
Any PC using the AMD USB architecture is preventing the printer from printing when connecting via USB.
What to do
Follow the specific steps for the PC manufaturer below:
Dell Studio 1536:
IMPORTANT: Do not replace any hardware, before performing the following steps:
Step Action 1 Go to Control Panel 2 Go to Programs and Features 3 Uninstall AMD USB Audio Driver Filter
Note: Uninstalling this USB audio driver doesn't cause any impact for systems with Vista Service Pack 1 installed
Acer Aspire 5530, Extensa 4130, Extensa 4430, and TravelMate 4530:
There are files available to address printing problems when connected to a USB printer or multi-function printer, for Windows Vista and Windows XP.
  • Printer did not print, print jobs will be listed with the status "error" in the task list
  • No error message appears, printer simply does not print
  • Problem only manifests when the printer is connected via USB
Please go to the Drivers and Downloads area to get the file appropriate for your operating system and unit.
US Customers:
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_Vista_Setup.msi
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_XP_Setup.exe
EMEA Customers:
ftp://ftp.work.acer-euro.com/notebook/aspire_5530/vista/Drivers/USBFilter107_Vista.zip
IMPORTANT: The third-party products discussed in this article are manufactured by companies that are independent of Lexmark. Lexmark makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
Still need help?
If you need additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need your printer model/machine type and serial number.
Please call from near the printer and computer in case the technician on the phone asks you to perform a task involving these devices.
I hope it helps!!!
Nov 30, 2008 | Lexmark X2500 All-In-One Printer
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
I have a lexmark x4580 and was working quite happily over the last few days. i replaced its ink cartridge a week ago and just printing some documnets , it threw up an error message " rigt and left...
Clean and make sure to put it back exactly as you got it, incase you are like me sometimes, i take pictures before i remove an object, so that way i can go back and look at the picture to make sure i get it back in right
Nov 04, 2008 | Office Equipment & Supplies
Files wont print
Apple's troubleshooting guide for OS9 can be found here:
http://docs.info.apple.com/article.html?artnum=106912
Jan 11, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
