Question about Cycling
The chain keeps skipping and wont run right - Cycling
    Brigadier General:
  • 8,546 Answers
My for f250 heavy duty will crank but wont start. what cold be the problem?
thats a tough truck
start with a a fuel delivery problem
if diesel glow plugs
if petrol check spark at the plugs
its a timing chain motor doubt if it broke a chain or skipped a tooth
Apr 01, 2017 | Cars & Trucks
Chain keeps skipping while I'm peddling
This is usually the setting of the rear shift.
Check that the rear d?railleur is properly aligned when it is set to the middle sprocket in the cassette.
The chain must be fed exactly to the middle of the sprocket teeth
Aug 02, 2015 | Columbia Sportswear Columbia Trailhead...
Can the timing chain come off or break. If so does that mean the whole car will stop running?
Absolutely. The timing chain is kind of like your spinal cord. It keeps everything running in perfect time. It lines up the the cams, valves, and pistons so that each cylinder is in position to recieve spark and create combustion to keep the engine running. It is very possible for for the chain or belt to break or jump a tooth if not properly maintained. Hopefully this did not occur while your engine was running, as this could result in extensive system damage, such as bent valves. You need to have this checked out by a trusted mechanic. If you don't know one, ask around with your friends and co-workers. If your timing chain did indeed break or skip, this needs to be handled by a pro, as this is a very intricate process.
Aug 30, 2011 | 2004 Mazda 6
As I pedal my Trek 800, the pedal slips or skips about one eighth of a turn. It seems like the chain is skipping a link or two ??
Your chain may have a stiff link or links. It is important to keep your chain lubed. TriFlow is highly recommended. Watch you chain as it passes through the jockey wheels on the rear derailleur, you should easily find the stiff links. Use WD40 to break it loose and work it with pliers.
Jul 01, 2011 | Cycling
16" chain, 16" bar it
You're not tightening the nut tight enough.
Apr 17, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a 94 Nissan pickup it has a 2.4 KA24E. I had to replce the timing chain and sprocket. I went by the book and it will not start.? I move the distributor back and forth and it try's to fire but wont....
What up? I got a 85 nissan 720 4x4 2.4, with Weber,never had a issue with my timing chain,got a remanufactured Jasper motor, now have 55,000 miles on it,truck has 343,000 on speedo,had it since 93.Here's a link on a repair guide for your timing chain. Repair Guides Engine Mechanical Timing Chain And Tensioner AutoZone com
Jul 03, 2017 | 1994 Nissan King Cab
Replaced timing chain now truck has no power
You know, I am having a very similar problem right now. I replaced the timing chain and it was running really bad. I thought it had skipped a tooth on the crankshaft somehow. Turns out it hadn't. and I have no idea at this point what I did.
Review the process. TDC #1 with marked links lining up with cam and crank sprocket marks. Mark distributor rotor at #1.(when you remove the oil pump, the drive cog will twist) so you must put everything together keeping it at TDC and line up distributor with marks. Then time it.
Mar 03, 2011 | 1997 Nissan Pickup
My crank/chain is skipping on my mongoose pro bmx. This just started when I was riding it, and it skipped. The chain is in the right right place and does not seem to be skipping place, but the crank is...
It seems you will need more tension on the chain. Place the bike upside down, loosen the nuts, grab a broom stick or bar and place it between the rear tire and crank housing straight up and down with the handle bars away from you, push the bar away from you. When done properly the tire will come toward you tightening the slack in the chain. While you hold pressure on the bar tighten the nuts and WALLA.
Dec 04, 2009 | Cycling
Popping skipping chain
how long have you had the chain on your bike? it may be worn (or your rear cassette may be) if skipping is occurring. have you attempted to adjust your shifters as well?
May 01, 2009 | Cycling
Cycling Logo
26 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
