Question about NEC ND-3500A DVD±RW Dual Layer Burner
Dont write dvd ram (with nero, roxioeasy c-dvd etc.) thenk for huors help
  • NEC Master
  • 27,725 Answers
Make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 27, 2011
Nero burning software
You may refer to this step by step guide, it will show you how to burn files to DVD/CD, including songs, video, photos, data, ISO files, etc. It's easy to understand and safe.
http://www.freedvdripper.net/how-to-burn-song-photo-data-video-to-dvd-cd-bluray.html
Hope it helps, email me if you need further assistant.
Oct 19, 2013 | Samsung Super-WriteMaster SE-S184M DVD-RAM...
Dont know how to burn a disc. no instruction on the CD provided
u need a software called Nero which will make it easy for u
Jul 15, 2011 | Toshiba Computers & Internet
I dont know does ASUS k50IP have hardware to burn files to DVD.so does it have...answer please...
You have DVD Super Multi is a term used to label DVD recorders that support both "minus" (DVD-R/DVD-RW) and "plus" (DVD+R/DVD+RW) DVD formats, as well as DVD-RAM...so it can record or burn.. what you need to check next is, if you have a software to use in burning, most of the people i know of are using NERO, mine is NERO 10 suite thats includes movie editing and stuff.. :) let me know if you need more help .
Jul 06, 2011 | Computers & Internet
In my sony dvd writer(DRU 8705), the prblm is that when i write any data frm my HDD into a dual layer dvd, the burn process succesfully completes but after that when i try to run the datas such as games,...
Hi ,
For video , use NERO Recode
For data , use NERO Burning Rom
If the issue persists , try using burning with another unit and compare the results . If you are still stuck , change software . If this still doesn't work , install Malwarebytes and make a full deep scan of your system ( http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html )
One of these solutions should help .
Best regards .
Jan 22, 2011 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
I have a X205-S9349 and after I upgraded to Windows 7, the HD DvD drive does not write cd/dvd's. There is no problem in reading. The driver says it is a 'matshita dvd-ram uj-850s'. But am not sure if the...
Did u Upgrade your System with the Original Windows 7 DVD?
thes might be the Course....
If Yes..
try to Install a Software that Rights..
like NERO Smart, Nero 8 or 9 etc..
if the Problem persist..
then ur Drive is gettng Weak
Dec 21, 2010 | Toshiba Satellite X205-S9349 Notebook
Just purchased, and trying to install HP dvd1170e DVD-RAM Burner. It is recognized, but cumputer running Windows XP does not fine driver, and dvd1170e is not functional. How do I solve this?
These devices require software to burn DVD's and CD's that is NOT just a driver...
A driver is not enough... typical software is NERO and other such as CD Creator, etc..
A DVD is quite different than talking to a USB memory stick or even a hard drive and you can;t just copy a file to it like you can a hard drive.
Typically using programs such as NERO, you copy to a list within NERO and when you tell it to burn the disc, it gathers all the pieces you have selected and goes about the operation...
May 16, 2010 | HP dvd1170e DVD-RAM Burner
Nero cannot burn DVD inserted in my LG GSA-H55N DVD-RAM rewriter
Have you tried other discs, or just that one? It might be that the disc you've inserted already has something written on it, and you can't burn a DVD-R twice. From the error message you're getting, that would be my guess.
Aug 10, 2009 | LG GSA-H55N DVD-RAM Burner
Low burn speed
I had the same problem before upgrading my RAM. Seems video burning software like nero are RAM hogs; if you do not have a large amount of RAM then it slowers the burning speed down to a crawl.[ BTW I didn't get maximum burning speeds using nero on a Windows Vista computer until I upgraded to 2 GB RAM] Hope this helps & please remember to rate my answer.
Dec 31, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Nero 6.6.1.4 serial number
Try
Serial Nero 6.6.1.4 Serial:
1A23-9844-2054-3824-9512-7019
1A23-0831-6008-5106-1612-4640
1A23-6795-3104-8985-6921-1244
By Chica
Oct 13, 2008 | Ahead Software Nero 6.6 (600901) for PC
NEC ND-3500A DVD±RW Dual Layer Burner Logo
48 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
