Question about Garden
Black and decker electric hedge trimmer makes a loud noise, motor hums and blades won't work. Loaned it to friend. Big mistake.
  • 1,383 Answers
Thats a BIG 10-4.. GOOD BUDDY . loosen the bolts that clamp the blade together. NO DRINKING WHEN WORKING ON THE FINGER TRIMMER !!!.. after the bolts are lose try it again. it may just have a bent tooth.. if not you can't do any harm, just start taking it apart, take pictures,. so if it is something stupid wrong you can reassemble it.. make up a repair bill for 25.00 on you computer and give it to him
Posted on May 27, 2011
I have an 8104 type 7 black and decker hedge trimmer. It freezes up durning the cutting or just squeezing the trigger. Makes a loud buzzing noise. Almost like it is jammed and there is nothing jammed in...
Did you ever oil the cutters since you have owned it? Try this spray some PB Blaster on the cutters let it soak and then try running it. If you can't find that stuff just try some motor oil, pour it on let it soak and give it a whirl. Good Luck...
Aug 24, 2011 | Black & Decker Decker Ht018 18" 26...
Electric hedge trimmer only hums when I turn it on. It accidently went through a metal fence. The blade is slilghtly concaved. The hedge trimmer is a black and decker tr1700. I've taken the cover...
look carefully along the teeth of the cutter blades and see if one tooth has not jumped over the opposite tooth thereby locking the blades together
a bent up edge will do the same effect
you can remove the cutter bar and then the cutter bar cams then run the motor
if it still hums , junk it
Oct 07, 2017 | Electric Garden
My Hedge trimmer will start and run for 2 or 3 minutes, then it dies and will not start again until the next day. Any ideas what is wrong?
Withou make and model it's tough to be accurate so I'll need to make a presumption that it's electric.
First clean the blades thoroughly then spray them liberally with a light oil like WD40
It sounds like the blades are binding and causing a thermal shutdown of the motor. Allowing it to sit over night resets the thermal circuit breaker
May 24, 2011 | Black & Decker 22" Electric Hedge Trimmer
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Hi! There is power to the unit....the blades don't move.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
What I did:
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Garden Logo
432 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
