Hello, i have an ACER aspire 5520 and every time i turn on he keeps turning off and on every 2 seconds without showing nothing on the screen or anything else , just rebooting all the time. I have try to take of the ram, the hard drive the optical drive and nothing still the same. Can you help me with this ? Thanks
  • 1 more comment
  • RUI MOREIRA
    RUI MOREIRA May 27, 2011
    Thanks for the answer, i try to do it and nothing, still the same :(
  • RUI MOREIRA
    Thanks, i wonder if you have a clue what part of the motherboard can be, because i have some electronic knolledge .thanks
  • RUI MOREIRA
    Thanks again :)
  • 2,632 Answers
Welcome to Fixya. Can you please try to do a power drain by removing the battery for 3-5 minutes and after that connect the AC adapter and try to turn it on without the battery see if you will still have the same issue. This case was nothing to do with the RAM, HD and ODD. Were trying to find out if this is an issue with the motherboard. Please let me know what happen.
Thanks
Posted on May 27, 2011
  • Rofel Lantican
    Rofel Lantican May 27, 2011
    HI - if draining the power of the motherboard wont help it seems to be that this is a hardware failure. If the laptop is restarting with no Display we can say that this is a problem with the motherboard. Some components on the motherboard is bad that is causing the issue. What i suggest is to check the warranty of the machine so that you can send it for repair free of charge. And most important please avoid to keep it turning on because if a component on a motherboard is bad and it keep on receiving power it can cause a problem on other hardware parts of the computer due to short curcuit. Thanks
  • Rofel Lantican
    Unfortunately sir we need to ask someone who is an expert on the parts of the motherboard. Acer would be able to check that for you. And just a heads up if the motherboard is the issue they will be replacing the whole motherboard.
Acer aspire 5520 shut down after turned on for a few seconds
Hi Chritina,
I understand the frustration but this issue happens if the issue is with the hardware. It may be due to overheating of the computer, any hardware conflicts or malfunction, or may be due to Operating System corruption. Please try the below steps:
1. Keep on tapping F2 key on your computer keyboard as soon as you hit the power button.
2. Then press F9 key, press "Y" to confirm and then Press "F10" and press "Y" to confirm, the computer will restart.
It should take care of the issue, however, if the issue still persists, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the data on the computer.
However, if the issue still persists then the computer needs a Motherboard replacement, in that case you may need to contact Acer Technical support at 1 800 816 2237 and arrange a Depot Repair for the computer.
Thanks and regards,
Jitha
Nov 20, 2011 | Acer Aspire 5520-5908 Notebook
I have a ASPIRE 5520 Laptop about 3 to 4 years old. The problem is that when you turn it on you can here the harddrive then it stops, a few seconds later you here it go again for about 5 seconds. It...
This is a typical indication that the hard drive has failed. Hopefully, you have a backup of the data on that hard drive as you will have to replace it with a new one.
Jan 08, 2011 | Acer Aspire 5520-5908 Notebook
My aspire 5520 tries to turn it on, in kind of loop, without success. It keeps dark screen and there is no bios access available. The 'ON button' and the 'HD led', both keep 'on' for around 3 seconds,...
Hi, Every PC-Laptop has BIOS otherwise nothing would work at all. Try turning the PC on & hold down ALT & F4 together that should get you into the BIOS. As far as having no display then your Video card must be not working & needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 06, 2017 | Acer Aspire 5520-5156 Laptop
My acer aspire 5520 keeps shutting down on boot. When i switch it on, its shows the boot screen then immediately shuts down. I had previously installed windows 7 on my second hard disk drive and the duel...
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Dec 24, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520 is stuck in an endless boot cycle.
hello:
thad are the best solution make a waranty note for store
if you think it are a hardware problem
other wize you loos you warenty
Aug 22, 2009 | Acer Aspire 5520-5579 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Black screen
The function keys to change the display is FN+F5. Hit that combination three of four times. If this does not work take it back tomorrow.
Dec 25, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
