Question about Sport & Outdoor - Others
Visual Studio 10_ArcMap_Addin: Imports ESRI.ArcGIS.ArcMapUI Imports ESRI.ArcGIS.Carto Imports ESRI.ArcGIS.Geodatabase Imports ESRI.ArcGIS.Geometry Public Class Buffer Inherits ESRI.ArcGIS.Desktop.AddIns.Button Public Sub New() End Sub Protected Overrides Sub OnClick() DescribeMe() End Sub Public Sub DescribeMe() 'DEklaration von Variablen Dim pMxDoc As IMxDocument Dim pActiveView As IActiveView Dim pGraphicsContainer As IGraphicsContainer Dim pEnumFeature As IEnumFeature Dim pFeature As IFeature Dim pTopoOp As ITopologicalOperator Dim pElement As IElement Dim strBufferDistance As String 'Referenz auf das ArcMap Dokument pMxDoc = My.ArcMap.Document 'Aktueller Datenrahmen pActiveView = pMxDoc.FocusMap pGraphicsContainer = pMxDoc.FocusMap If pMxDoc.FocusMap.SelectionCount = 0 Then Exit Sub strBufferDistance = InputBox("Enter Distance:", "Buffer") If strBufferDistance = " " Or Not IsNumeric(strBufferDistance) Then Exit Sub 'Liste aller Feature in der Map pEnumFeature = pMxDoc.FocusMap.FeatureSelection pEnumFeature.Reset() pFeature = pEnumFeature.Next Do While Not pFeature Is Nothing pTopoOp = pFeature.Shape pElement = New PolygonElement pElement.Geometry = pTopoOp.Buffer(CInt(strBufferDistance)) pGraphicsContainer.AddElement(pElement, 0) pFeature = pEnumFeature.Next Loop pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, Nothing, Nothing) End Sub Protected Overrides Sub OnUpdate() Enabled = My.ArcMap.Application IsNot Nothing End Sub End Class Bug:Could not write line to file "xxx". Access to the path: 'C:xxx is denied. Could you help please G.Klecak
Does the drawing board III use WinTab for arcGIS 10?
ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site: http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
Jan 10, 2013 | GTCO CalComp Drawing Board III 34480...
Trying to backup my 2415 iPaq. It used to save .exe files. Now, it only saves .pbf files. What's the difference - or does it make any difference at all? Also, I have a second iPaq that does NOT...
an .exe file is an EXEcutable file, it is the file that starts a program. It is not the backup data, but it may be the program that captures it.
Your .pbf files are indeed backup data files by Paragon backup and recovery program.
So, you would open Paragon using its .exe file and it backs up the data to .pbf files. To restore the files, you would open Paragon, and point to the last .pbf file or files to restore.
And yes, you could have Paragon Backup and Recovery on both machines and save the backups to a USB memory stick. What is on the memory stick can be accessed by Paragon on both machines. Make sure it is data only, rather than system files unless each computer is absolutely identical in model and spec.
PBF File Extension - What is a .pbf file and how do I open it?
https://fileinfo.com/extension/pbf
Backup archive created by one of Paragon's backup and recovery applications; stores backup files in a proprietary format; can be browsed within the software, which enables users to restore individual files or a whole file system. In addition to system backups, PBF files are often ...
File Extension .PBF Details
filext.com/file-extension/PBF Details for file extension: PBF - Grand Prix Legends BMAP (Bitmap) File :: PBF - Paragon Disk Image :: PBF - PBook E-book Format :: PBF - Portable Bitmap ...
How to view or import *.pbf file (OSM data, binary format) in ArcGIS for ...
https://gis.stackexchange.com/.../how-to-view-or-import-pbf-file-osm-data-binary-for... Oct 25, 2012 - The ArcGIS Editor for OSM (https://github.com/Esri/arcgis-osm-editor) should allow you to do what you want to do. Data is downloaded via the ...
Sep 02, 2017 | HP iPAQ HX2415 Pocket PC
INSTALLATION REQUIREMENTS a compatible version of visual studio 2008 was not detected on the system. this update is designed for only microsoft visual studio 2008(ENU) product family,and is not...
The software you're trying to install is an upgrade from the Microsoft Visual Studio 2005 Professional edition. If you do not have that version of Visual Studio installed, you won't be able to install the upgrade.
However, I would recommend you downloaded the Visual Studio 2010 Express edition, it's fully functional and I used it for a long time before upgrading to the professional edition. To be honest the only feature I use in the professional edition is the addon system. Plus, the 2010 Express edition is free and available for anyone.
Feb 26, 2011 | Microsoft Visual Studio 2008 Professional...
Cannot Install Visual Studio 2008 on Windows Vista
From the message you get one infers that this is not the full program, but an upgrade to a previous version of Visual Studio. Even if you have a Visual Studio Express edition already installed on your computer, this update is not compatible with it.
Hope it clarifies the message.
Sep 04, 2009 | Microsoft Visual Studio 2008 Professional...
Visual Studio 6 Vista compatible?
According to MSDN Visual studio 2005 works on vista ( see here ) . But as a developer, i can suggest you, if it not works, you can easily maintain a dual boot system with another HDD. That would be better for you. A lot of developing tool can not work with vista. I started using vista and threw it away then.
Apr 21, 2009 | Microsoft Mlf Visual Studio Enterprise...
How i can download vb on my pc for windos98
Here the download for visual basic environment on windows 98
Download details: Visual Basic 6.0
If you instead want to do programming, then you need to download Visual studio 2005, that runs on Windows 98.
You can download Cisula Studio 2005 from the link below:
Download details: Visual Studio® 2005 Express Editions SP1
Feb 28, 2009 | Microsoft Visual Basic Professional...
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
From which site i can download microsoft visual studio.
what u can do is try this u can install it for free or u can install it by paying it .....
http://www.brothersoft.com/downloads/visual-studio-6.0-download.html
http://www.download.com/Visual-Studio-2005-SP1/3000-10250_4-10618634.html
http://downloads.phpnuke.org/download/microsoft+visual+studio+free+download.htm
http://www.developers.net/appdevshowcase/view/3188
Jan 27, 2009 | Microsoft Visual Studio 2005 Professional...
Microsoft visual studio 2005
Hi Manpreet,
I am working as a dot net team leader. I am GNIIT, and have 3 years of experience in dot net
you can download the express edition of Visual Studio 2005 from http://www.microsoft.com/express/2005/ express edition is free. Install the application and get going you can post any more questions here or you can talk to me at matharuajay@yahoo.co.in or ajmatharu@gmail.com
I would love to help you.
Oct 25, 2008 | Microsoft Mlf Visual Studio Enterprise...
Visual studio
hi dear jane
there are some temprore files of the V.S u have find these file and uninstall them
for example : c:\program files\ Microsoft Visual Studio
u have delete these folder manually
i hope its work
Aug 06, 2008 | Microsoft Computers & Internet
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
