Question about HP Color LaserJet 2600n Printer
I refill toner but the machine inform toner incorrec
  • HP Master
  • 1,915 Answers
These cartridges have a chip on them that must be replaced. Most reputable vendors of toner will tell you this and sell you the correct chip.
Posted on May 28, 2011
AR5731 Undetected
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
"set the toner cartridge correctly"
Possible the chip that reads the toner bottles shorted out.
Try new bottles. If that don't work, the board in the machine that reads them need replacing.
You will need a technician to replace them.
Mar 29, 2017 | Ricoh SP C430DN Laser Printer
We can refill the HP LaserJet M1005 Printer toner
Yes you can, but toners are not universal and each machine requires its own specific toner. There are outlets that refill toner cartridges with the correct blend of toner. There is another way to economise on the cost of toner but this is severely frowned upon, is very messy and should only be done on a machine where the drum is part of the toner cartridge.
Jan 25, 2011 | HP LaserJet M1005 Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
How shall we reser the empty toner message, while refill the toner
Make and Model??
Most fax machines use a replaceable toner cartridge that resets the counter when you change it.
Refilling a toner cartridge is impractical for the user.
Sep 20, 2010 | Office Equipment & Supplies
I was used samsung scx-4300 printer used refilling cartridge printed some print then shows low toner then after some prints they shows toner exhausted replace toner my mail id is nagaiah_t@yahoo.co.in
Good day,
To order Samsung-Authorized toner cartridge contact your local samsung dealer or retailer where you purchased your machine, or visit www.samsungprinter.com and select your country/region for information on calling for technical support.
have a nice day!
Aug 04, 2010 | Samsung SCX-4300 Monochrome Laser...
Refill toner for samsung 4300
Good day Sir,
I suggest do not refill the toner cartridge. The machine warranty does not cover damage caused by using a refilled toner cartridge.
Always replace it with a new one and make sure the cartridge is genuine to prevent toner errors.
have a nice day!
Apr 20, 2010 | Samsung SCX-4300 Monochrome Laser...
How to refill toner
Toner refill is not recommended. As this may spoil the machine main board. and will end up with spending more than what is required to get the genuine toner. Because samsung has its own secret in the main board to Combat the fake/refilled toner.
But you would like to install the genuine toner then. Open the front cover and just pull the toner bottles and replace them.
Nov 08, 2009 | Samsung CLP 300 Laser Printer
Copier won't print after refilling toner cartridge
As far as I know, filling up with toner is not enough. There is an electronic chip that must also be replaced, so the toner cartridge tells the unit it is a new one. Check with your supplier for such chip.
Oct 14, 2008 | Sharp AL 1631 Copier
Refill
Hai
Well u can refill the toner,to refill the toner u should contact the nearby service station to refill.
Sep 09, 2008 | Xerox Black Toner Cartridge 25000 Page...
HP Color LaserJet 2600n Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
