Question about Whirlpool SF379LEKS Gas Kitchen Range
The display on the oven does not operate. what can i do about it.
Heard a loud "Pop" sound, now oven won't work and lost digital display. Stove and lights (even in oven) all work fine. Breaker did NOT trip btw. Odd.
When my range digital display lights failed everything as you describe happened except the "pop". The display just faded and died. I replaced the display unit (a simple swap out involving pulling the wires one at a time and reconnecting to the new display as I pulled them so as not to connect wrongly). Once done I haven't had a problem since and the display was noticeably brighter. It appears that the display unit only affects the ovens operation for heat control and everything else is on a different circuit which is why your oven light and rings are still operational.
Mar 02, 2016 | Kitchen Ranges
Whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Apr 27, 2008 | Whirlpool GH9185XL Microwave Oven
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Feb 15, 2008 | Microwave Ovens
Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
Whirlpool SF379LEKS Gas Kitchen Range Logo
16 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
