Question about Fujitsu fi-4120C Path-Through Scanner
Scanner is able to scan both sides of documents, but will not scan both sides of a yellow document, and ther images are faded on yellow documents also.
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
SOURCE: how to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
  • 86 Answers
SOURCE: Horizontal Lines
This might be a hardware problem, but it could also be caused by an outdated (or corrupted) driver; you could uninstall the original driver, then download and install the newest version directly from HP here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=446435&lc=en&jumpid=reg_R1002_USEN
If that link is broken, or doesn't work for you, use this one:
http://tinyurl.com/2n7lge
Also, I've copied the following information directly from the HP 4850 Scanjet user's manual:
If you have the HP Image Zone software installed, you can use the onscreen Help to solve other problems with the scanner. To gain access to the Help, open HP Solution Center, click Help, and then click HP Scanjet 4800 series scanner Help. The Help system provides information about the HP Scanjet 4800 series scanner hardware as well as information about the HP Image Zone and HP Scanning software itself. Also, see Scan troubleshooting in the general Troubleshooting and support section of the Help.
Good luck with this; let us know what you learn...
Posted on Jan 28, 2008
mohanchennai
  • 490 Answers
SOURCE: Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Posted on Feb 21, 2008
mohanchennai
  • 490 Answers
SOURCE: DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Posted on Apr 03, 2008
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
Feb 02, 2015 | Epson Office Equipment & Supplies
Right side of document is black when scanning to print, umax 1220u
1. Fred's right about trying another computer, but you still may have wrong/ old driver- download demo version of Vuescan at www.hamrick.com and see if it's your software.
2. Partially blank pages can appear when you don't have sufficient memory for the scan, but that usuall loosees the lower half of the page.
3. The lamp is probably not the problem, because there is enough liht bouncing around in mostflatbead scanners that you would just see the image "fade"to black, not have a distinct line.
4. best bet is that something inside has come loose and is covering half the scanning sensor, or the mirrors that reflect the images to the sensor inside
Dec 24, 2012 | Umax Astra 1220U Flatbed Scanner
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
My HP C4750 scanner will only save a scanned document page as an image, TIFF, JPEG, etc. Always as an image even when I say to save as a Word document. Please tell me how I can overcome this. Doug...
Scanners only save word documents as images there is no way by which a scanner will save a scanned document as a word document. Although there are 3rd party applications which can help convert your scanned items from image to word documents. To get these applications go to google and type "convert PDF to word document" on google and a host of available applications will be displayed go through and download the one which suites your use more.
Hope this solution has been helpful?
Dec 07, 2010 | Computers & Internet
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
Color is faded on one side when scanned
Apparently you might need to because scanners are most times not reserviceablw when problems of faded output and discolouration is evident.
Properly clean the surface of the scanner and leave your scanning image application to default settings
May 28, 2009 | Office Equipment & Supplies
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Jan 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Fujitsu fi-4120C Path-Through Scanner Logo
55 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
