Phillips 32" Matchline Pixel Plus TV. The picture intermittently turns red/purple when the background is set at night or is a dark picture generally. After a while there is a "click" and the colour rectifies itself back to normal picture. Sometimes the picture disappears altogether, sound remains then the picture returns. When the tv is first switched on sometimes there is a flickering in the centre of the screen. it resolves when the TV is switched off/on again. Is this a tube problem or do we need a new TV? Thank you.
SOURCE:
ladywinn
  • 5138 Answers
SOURCE: TV flickers and clicks for 15 minutes after powerup,
replace tuner borads.
Posted on Mar 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: The TV is a Phillips
The TV is going into protective shutdown. What is the model number of your set? I may be able to help you depending on the chassis number.
Posted on Mar 13, 2008
SOURCE: Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
Posted on Sep 04, 2008
  • 254 Answers
SOURCE: I have a Samsung HLR6168W DLP that intermittently
its the problem of inner lamp that is near to end of its life and it needs replacement.and what the thing is happening is the indication of faulty lamp.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Mar 11, 2009
SOURCE: My Philips Matchline TV won't
Have 1 Philips 42fd9944/ois plasma it cant power up just make a noise on the relay. can i get service Manuel. henry
Posted on Jun 16, 2009
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
Picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Nov 03, 2012 | Samsung LN32C350 32 in. TV
My webcam get dark background even all lights on.camera setting are ok...during the night i can only see bright light and the rest are black,pls help me.
This camera does not have sensor & night vision , even its not a mega pixel camera. Its just a VGA camera. So you need to buy a Night vision cam cost approx 15$ - 20$. thanks.
Jan 20, 2011 | A4tech PK-635 Webcam
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
I have a phillips matchline plasma the power light keeps flashing green then starts flashing red is there a problem with the connection between the tv and the master box?? plz help!
According to " Consumer Affairs. com", the problems with seris of Phillips plasmas are innumberable. And they all start with the flashing red light, from 3 - 7 times. Baased on the information you gave, there is something wrong with the TV itself, not your perifrials. I would contact Phillips/ Magnavox to see if they will pay for an authorized sevice center visit, or even ship you a part to solve the problem.
Apr 11, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
The TV is a Phillips Matchline 55"; wide screen, approx 7 years old.When switched on the LED goes red then there is a clicking sound then the LED blinks red continuosly and there is no picture.
Mar 13, 2008 | Televison & Video
HAI
Start by going to a good college and studying electronics 101 followed by electronics 102, math, algbra, etc, until you get an engineering degree. Now as for the dark purple and blue. It sounds as though you have a picture tube getting weak in the red gun and unless you can turn the red gun up you may need a new set. Anyway, good luck and have a great week
Ed
NC Electronic
MIlls Wyoming
Jan 06, 2008 | St. Moritz Bellagio Flyback Chronograph...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Ekse
