Coleman pw70-1200 pressure washer locked up . throw circuit breaker
2 Suggested Answers
mkh5094
  • 145 Answers
SOURCE: Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Posted on May 02, 2010
Throws the circuit breakers when electricity is activated on generator
I need more info. Describe exactly the sequence of what you do tomake which circiut breakers blow ... the ones on the generator orelsewhere? Do you have a load connected to the gen? If so,
what is the load?
Feb 26, 2015 | Coleman Powermate Premium Plus 6250W...
Why does the machines cct breaker trip on a simoniz S2000 XE02 pressure washer
It could trip for a number of reasons. If you turn it on and nothing happens for a few seconds or instantly trips the motor is overloaded or burned up or a motor capacitor is bad. If the machine turns on and sprays if you hold the trigger open while you turn it on and then trips when you let go of the trigger you probably have a problem with the cut off switch . The circuit breaker might be too small for the load of your machine. The extension cord might be too light duty and causing the breaker to trip.
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Husky pressure washer is tripping my circuit
throw it away and go by another one...
Nov 03, 2013 | Garden
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Throwing Breaker
you could have a couple of reasons.If you use an extention cord that is too small,If the circut is overloaded.Bad breaker,good luck!
Jul 08, 2009 | Coleman Propane Forced Air Heater...
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
