Question about Garden
I have a Troy Built GVC 160 (2600 psi) pressure washer. I used yesterday afternoon without problem. Today, I can get it started, but it conks out immediately as soon as I engage the wand. I'd appreciate any help you can provide.
    President:
  • 1,388 Answers
Make sure that the engine is set to full power. Lower the pressure to the unit with the pressure adjust knob as much as possible. Check the nozzle to make sure that no debris has entered and is lodged at the tip of the wand. Start the engine with the spray gun handle in the open /on position allowing water to flow thru. Allow the engine to run for a while to warm-up. Increase the pressure a small amount at a time to reach the desired pressure. To increase the life of the unit, do not use the machine at max. pressure setting. Adjust to about 75% of rated capacity and increase only for stubborn debris then reduce. Good luck
Posted on May 27, 2011
  • bcmoorhead May 27, 2011
    Thanks for your help, but I ended up having to take it to be serviced. Covered under extended warranty.
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
