Question about Husqvarna Garden
What is the part number for 42 inch mower deck spring for the for Husqvarna THY 150?
  • 407 Answers
Http://www.partstree.com/parts/
The above link is a great place for parts.You will have to enter some information,like model numbers,but it is easy to use.
But first.Lift the hood,there should be a small sticker with some part numbers and a phone number.Call that number even if the spring is not listed.
Posted on May 27, 2011
Hitch pin clip broke that holds up mower deck. Mower deck about 1/2 inch shorter on one side. Rod to hold mower deck to frame will not stay flush when I try to tighten bolt to raise deck
YOUL NEED TO REPLACE THE ENTIER HICH PIN SYSTEM THE BITS MIGHT BE COASTLY THOUGH SORRY ITS TOO SHORT TO ALINGE NOW NO WAY YOU COULD REATACH THE DECK SAFETLY UNLESS YOU GETVA QUalified welder to manufaturecyou a knew which PIN bit and a fix it etcetera.
Aug 02, 2015 | Husqvarna RZ4219 42 inch 19.5 HP Briggs &...
How do i troubleshoot 42 inch craftsman lawn tractor on which the mower deck quit engageing
Most likeley is a spring on the top of the deck or the cable that goes from said spring to the lever. if you could provide the model number I can look up the manual and diagram and show you.
Jun 29, 2014 | Craftsman Garden
I've got a 2005 husqvarna yth 2042 riding mower,i broke one of the belt guides,(on order)-the spring extension for the clutch,where does it hook to?
Not too sure which guide you are refering too, the only keeper at the clutch is the anti rotation bracket for the clutch itself, it bolts to the side of the chassis and the other end sits into a cut a way in the side of the clutch assembly.
Apr 24, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
What size and how many blades do I need for my husqvarna 21 hp riding mower with a 46 inch deck?
Well I guess laying down next to it and taking a look under the mower deck is beyond the question. One could ask about how many teeth the horse has or just look in its mouth. However, I am going to guess 3 blades as 2 blade units usually are 42" cut maximum. Mine is 48" and has 3 blades.
Mar 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I would like to know the part number of the electric clutch on my Husqvarna YTH1700 mower (42" cutting deck).
went on the husqvarna website and couldn't find a yth with a 42 inch deck - found a yth1746, though and the part number is 532145028
Aug 20, 2009 | Husqvarna Garden
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
