Question about MA Audio HK4000D Car Audio Amplifier
Ok did aight i noticed that my 90amp fuse running under the hood is blown i relplacd and it blew within 30 sec and my capacitor got hot instanly ,,,,,,,,,,,,,,whats that mean
  • 631 Answers
It sounds like the capacitor is connected backwards (+/- polarity) or is defective..
Posted on Aug 16, 2008
SOURCE:
Smokes and smells like gas at muffler
That has to be gas that is not being burned! No idea why blowing a fuse with the air compressor rashed your car like that - must be coincidental or collateral damage.
Sep 04, 2017 | 1994 Ford Mustang
No ac nd my fan stop working completely
Fuses blow because of higher than normal amperage in the circuit. Not sure what circuit the blown fuse is for but if it is for the fan the fan may be shorted therefore blowing the fuse. If you put fuse in while the ac was still on try shutting off the ac then putting the fuse in. See if it blows then if it doesn't then turn the ac on and if it blows you have at the very least isolated the system at fault.
Jun 16, 2012 | 2001 Chevrolet Impala
I own a 2002 grand am gt the fans dont work so the car overheats
The most common problem I see is a blown cooling fan fuse, usually a 30 - 50 amp fuse and it's larger than the usual small push in fuses and is usually located under the hood in a fuse and relay panel. If you live in a northern climate the fans will often become frozen in place with ice and snow and cause the fuse to blow when they try to run. It's usually not noticed until hot weather hits then the engine will overheat because the fans can't run due to the blown fuse. You could also have a bad fan motor that has just simply quit so if you find that all the fuses are good then that is certainly a possibility. Hope this helps you out a bit!
Jun 25, 2010 | 2000 Pontiac Grand Am GT
Emerson Microwave Model MW8119SB found blown fuse. Replaced fuse power came back punched in 10 sec started microwave and fuse blew again.
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Brake light fuse keeps blowing Noticed our brake ligths were not working...checked the fuses under the dash and they were fine...checked under the hood and found one blown...replaced it and the brake...
Take a look at the wiring to the brake lights. It is quite possible that over the years one of the wires has rubbed against another enough to short out, causing the blown fuses.
Jul 17, 2009 | 1998 Mazda Protege
Blew a fuse for my power windows looked in both boxes under dash and under hood looked in manual does not show a number or location
on my 1997 explorer the power window and door lock fuse is under the hood. fuse box driver side, passenger side of fuse box, 5th or 6th from front of vehicle. I now use fuses with LED in them so when they go out they light up bright red. easy to see even in full sunlight. cost about 3 dollars more but worth it. 30 Amp fuse.
May 05, 2009 | 1997 Ford Explorer AWD
Car was driving down the road and died
Dis fuse was blown? What about dat one next to it? Just kidding. Is rhat meant to read dist? Check under hood fot loose or shorted wiring around the distributor. and coil.
Mar 25, 2009 | 1993 Chevrolet Lumina
1996 LX - Condenser Fan Blows Fuse
Check the cooling fan relay under the hood on passanger side.
Aug 17, 2008 | 1997 Honda Civic
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
Top MA Audio Car Audio & Video Experts
Mark Skinner
Fahr Quad
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
