Question about Sony CFD-C1000 Cassette/CD Boombox
The cd player will not rotate or operate. - Sony CFD-C1000 Cassette/CD Boombox
  • goodsmith19 May 27, 2011
    The power source works fine. When you turn on the player there is a grinding noise which continues when you try to open the cd box or play a cd which the player will not do. Yes, it is an older model, I believed purchased around 2001. Where is this fuse you are referring to?
    Top Expert:
  • Sony Master
  • 75,424 Answers
Hello
Check whether the power is coming to its power socket or not. If not check the AC power chord. If there is power at the power socket, and still the device does not work, check the fuse [glass cartridge type], inside it. If fuse is also OK, check its mains transformer. You can check its mains transformer with a multimeter set to KOms range. There must show continuity with the meter. These are only possiblity for a dead device. Your device is an old model I thinks. If so, component availability will be rare. If transformer has burned, it can only be rewinded. OK.
Posted on May 27, 2011
  • The Knight
    The Knight May 27, 2011
    If the power supply is correct, there is no question arises with fuse. I thought it is totally dead, and that is why I described about it. There is some crakced wheels, or worn out ones that makes the noise. To rectify this, you have to take out disassemble its CD mechanism. It is unpredictable, which wheel makes the trouble. Anyway it is purely a mechanical problem. I've contacted Sony here, but they have no documents about this set with them now, and says it is outdated. We have to find out the reasone for this noise ourselves in short. OK.
Discplayerwontplay open or rotate
You will need to take off the surround metal and look down into the disc changer. There are gears mixed with small belt drives that are used to open and rotate the disc changer. If the teeth of the gear or the rubberbands are snapped this will cause the player to not work properly.
Please accept if this helpful.
Thank you
Mar 03, 2011 | Kenwood CD-203 5-Disc CD Changer
CD player stops rotating then starts back up
This could be a problem with the CD player itself or the CD control board. I can repair both of these, please email for help, tech@wurlitzer-ohio.com.
Nov 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
Spin both directions theb display show table error
Usually CD rotates in the clockwise direction. Whenever you are using CD which your CD player cannot detect then CD is rejected and suddenly CD rotates in anticlockwise direction.
Also, If your player is older and your CD players laser head worn out then CD's which were played good previously cannot be played properly and then stop in middle, when this happens you can see CD rotating in anti direction.
Clean the laser head, with CD cleaner and do not use scratched CD's
Aug 26, 2010 | Sony CDP-CX300 CD Player
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Spares ?fboxor the rowe cd 100 juke
have the motor replaced and the rotate switch just to be sure..
Nov 13, 2009 | Wurlitzer Jukebox CD Player
Panasonic cd player sa-ak75 showing fault 61 on display screen,machine will not fire up regards derek
check fan it might not be rotating.the fan should rotate when increasing the volume.check also the power module ic
Mar 06, 2009 | Audio Players & Recorders
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
The cd doesn't rotate/or isn't read
ok if you know how to clean up kit for cd,s and if it works your re done...see the problem continues you have to change the laser just tell yourself how many hours has the laser on operation. and if its worthly....saludos
Nov 17, 2008 | Audio Players & Recorders
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Open Questions:
Sony CFD-C1000 Cassette/CD Boombox Logo
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
