Question about Toshiba 46HM95 46" HDTV
Dlp picture problems
Why do the colors seem to be distorted especially on peoples faces and bodies. seems to have yellow blotches? after about a half an hour, my dlp starts to get that "moving moss" look especially on peoples faces and then after about an hour of being on, the picture starts to flicker. i tried a new lamp and that didnt help and there are no humming or buzzing sounds.
  • ccooley Dec 06, 2008
    I have the Mitsubishi WD-65 and have been experiencing this problem for the past month. I called a TV repair man, and he was of no help. To solve the problem, I removed the back panel and vacuumed the entire inside of the mechanical area. Because I couldn't get to the color wheel to get the dust off that area, I blew forcefully into the fan area and TONS of dust flew out. I repeated this until no more dust came out. I have not had this problem again.
  • 157 Answers
Try and do a factory reset based on what is written in the manual. If this doesnt help, Check if the TV is set on NTSC or PAL.
Try also a different input on ur TV like scarf or s-video
Cheers
Posted on Sep 03, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
You might try a different display format, like 1080i vs. 1080p, although the p (progressive scan) should have less flicker due to the fact that the frame is scanned completely before another frame is scanned, while the i (interlaced) weaves frames together by scanning alternate horizontal scan lines and interlacing the images.
When things look good, then begin to flicker, then stabilize again, it's almost a description of a sync issue, or you are able to perceive the flicker that is truly there, but presumably happenening at a rate above your perceptual threshold, much like flourescent lights actually flicker, but at 60 Hz (cycles per second) most (but not all) people don't see any flickering.
thanks
good luck
Posted on Aug 16, 2008
    Genius:
  • 1,011 Answers
Dear,
if you have checked it by changing the lamp then there you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but dear plz dont touch that one.
regards,
  • SALMAN NASEER Aug 16, 2008
    dear,
    have u checked the settings that should be a standard to run it..
    or select a minimum requirement and then restart it..
    regards,
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Color distortion
I have a 2005 73" dlp . Your light engine is going bad ! soon you will have a pyschadilic light show then total failure. I've replaced 3, Mitsu paid for all of them. But its getting very old.....I'm about to replace a fourth as soon as i can get it scheduled. Don't wait too long to order it . it can take up to 3months to get it.
May 16, 2009 | Mitsubishi WD73727 73" HDTV
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung LCD HDTV - Color Problems
voltage adjustment for y-sus board or power supply
Mar 17, 2008 | Televison & Video
Dlp tv picture flickers and reds have yellow blotches after the TV is on for more than an hour.
Could be color wheel problem--but u'll prolly have to change out the light engine $$$--Causes blotches---Good luck
Feb 05, 2008 | Televison & Video
Hp 42in plasma tv
There is some voltages that need adjusted in your tv and possibly the z sustain board needs replaced if the voltage adjustment doesn't fix it.
Dec 10, 2007 | HP PL4245N 42 in. HD-Ready Plasma...
Toshiba 46HM95 46" HDTV Logo
279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
