Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire GLRS264ZAQ5 fridge freezes up
Fridge side freezes up. Freezer is ok. Repairmen replaced the damper motor & cleared air from lines. Still not working properly. HELP!
Does the ice maker have to have the copper tubing?
Posted on Aug 21, 2008
Refrigerator side freezes
if the food in the fridge side is freezing it sounds like the damper door isn't closing,the way it works is cold air is produced in the freezer side,the evaporator fan blows the cold air from the freezer to the fridge side and it blows through the damper assy. if the damper door isn't closing youll have sub zero air constantly blowing into the fridge sidethe part number is 5304482075 but it's around 200 dollars.you can go here to sears and look up the parts or call a tech in to check it out
http://www.searspartsdirect.com/partsdirect/part-model/FRIGIDAIRE-Parts/Refrigerator-Parts/Model-FRS26R4AB0/1428/0165000/R0108022/00005?blt=06&prst=&shdMod=FRS26R4A
Jun 17, 2014 | Frigidaire FRS26R4A Side by Side...
Ice build up in freezer
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
This will help to solve the problem....
Aug 18, 2011 | Jenn-Air JCD2389G Side by Side...
Everything freezes in the refrigerator the setting knobs did nothing to help. looking on line everyone called out the damper as the problem replaced it and its no better what else could it be its #...
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for. Good luck in solving the problem...
Aug 08, 2011 | Frigidaire Refrigerators
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
My amerian fridge freeze the fridge is frezzing everything
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
Icemaker overfills and freezes solid so wont dispense. also freezer has frost on everything
I hope this help out....
May 07, 2011 | GE Americana A4425GDTWW Side by Side...
Lg fridge freezing food in freezer section
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
147 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
