THE WIRELESS ADAPTER ON MY LAPTOP NEED TO BE RESET CONSTANTLY. IS THERE A STETTING I SHOULD CHANGE OR DO I NEED TO REPLACE IT
  • 4,340 Answers
Try setting the router settings to channel 11. Interference with land line cordless phones (up to 1/2 mile away!) is the common issue.
Posted on May 27, 2011
Is there a wireless key somewhere
The wireless WIFI internet key is decided by your ROUTER not your laptop. If your internet connection is indeed by wireless and not by ethernet cable, you will need to find the router key, from your internet provider, guardian or if you are desperate, find the reset key on your router to reset the passkey to the factory default which will be shown on a sticky label on the router or in its manual. Punch this into the windows dialog box when required. Good Luck.
Dec 31, 2014 | Toshiba Satellite L25-S1192...
Every time the battery goes dead on my ASUS X83vm and plug in and turn it on, the clock/date reset and the recently replaced network adapter which was the same one maybe different version (Intel Pro 5100 I...
Most people do not realize that a laptop has 2 batteries... the normal 4-6-9 cell battery that we constantly recharge and a smaller (internal) battery to maintain CMOS memory where the clock and other data are stored.
The CMOS battery is normally inexpensive, typically you can find them in a good electronics store or even on ebay. They are easy to change as they typically have a quick disconnect plug. I am not sure where it is located on the ASUS, but look in the memory compartment or the hard drive compartment.
Aug 29, 2011 | ASUS X83Vm-X1 Notebook
I'm using a HP dv6-1101ax notebook. Recently, we switched to using a Belkin F5D8235-4 wireless N Router. Every laptop in the network works fine except for mine, which constantly disconnects about 5-30...
You cant trust HP anymore, my dad had 3 of their laptops and they all did the same thing and after about a year the motherboard crashed.
I suggest if you are sitting near the router, then buy a short LAN cable to hook up, then it should work.
Hope this helps
Mar 23, 2011 | Computers & Internet
My wireless internet isnt working on my ASUS laptop. The yellow exlamation mark is on the signal bar icons and when i go into the device manager the network adapters and tunneling pseudo-interface have the...
you will need the drivers updated or replace the network card. if the drivers from Asus do not repair the problem, then i suggest a new adapter. here is an inexpensive one from eBay.
http://cgi.ebay.com/Broadcom-54M-mini-pci-wireless-WIFI-laptop-network-card-/320521450172?pt=LH_DefaultDomain_0&hash=item4aa09132bc#ht_2166wt_978
i also recommend changing the antenna whenever you change the wireless network adapter.
http://cgi.ebay.com/WiFi-Antenna-laptop-wireless-mini-PCI-network-card-/220724436636?pt=LH_DefaultDomain_0&hash=item3364339e9c#ht_2091wt_862
since you did not list the model of the laptop this is my best guess at what you will need. if you can send the model number i could double check this application for you.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 03, 2011 | ASUS Computers & Internet
I have belkin g wireless that i have to constantly connect
I have experienced the same issue with belkin routers. First, test your laptop with other wireless connections {e.g. Starbucks, McDonalds, etc..} to see if your laptop's wireless adapter is working okay. If so then it sounds like your Belkin Router needs to be reset to the factory defaults and then your personal wireless network settings re-entered.
If that doesn't work it may have to be replaced.
Please provide feedback...
Mar 12, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Trying to hook another laptop on to the wireless internet but forgot the passphrase/ key code
if its the default then should be on your router... id you have changed it on the back/side of you router there should be a reset button (very small) need paperclip push it in and should reset to defaults. or from the pc attached type in 192.168.0.1in internet explorer to access set up page and change password
Feb 02, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
Windows Vista Ultimate: Internet connectivity
Make sure your IPv4 settings property is set to AutoObtain the IP address under the Network properties for the wireless card
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Acer Aspire Wireless Connection
hello
lets start with reinstalling the wireless drivers / software on the laptop.
open device manager by rightclicking my computer and select manage.
on the left side select device manager
then on the right side, find network adapters, open it from the + mark
right click on the wireless adapter and select uninstall. Then restart the pc. The wireless will be reinstalled when you start up the pc again.
See how your wireless works, if there is no change go back and right click on the wireless and select properties, then click on the drivers tab. and click on update driver, let it look for a update online if asked. if it doesnt find a update
you can get the newest wireless driver from acer at this website
http://support.acer-euro.com/drivers/downloads.html
May 13, 2008 | Acer Aspire 5050 Notebook
Netgear
You dont need your wireless adapter to setup your laptop however if you are going to setup or use your laptop to connect to a wireless connection you need your wireless adapter
Jan 22, 2008 | NetGear (IM-WG511T) Wireless Adapter
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
