Verbatim Model #USB160 JH8X12 computer does not recognize blue light just keep flashing no response.
  • 4 Answers
SOURCE: new verbatim 160gb usb external
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Posted on Mar 03, 2009
SOURCE: hi, my verbatim usb 250 is not working. It has a
i was goinng thorugh same thing for weeks didnt know what to do so i took it and held it with the slim side and smacked it softly on my nee and it works:D no joke:D try it not tooo hard or else itll brake:)
Posted on May 08, 2010
Damilare
  • 358 Answers
SOURCE: I've just bought a 250GB
Even though it is possible that your USB hard drive is corrupt, but
before you finally conclude, try out these few troubleshooting
steps.
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
goes
Hope this helps you out.
Thank you for using Fixya
Goodluck
Posted on Oct 07, 2010
  • 10406 Answers
SOURCE: I bought a verbatim 320
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Posted on Nov 01, 2010
walesarumi
  • 6993 Answers
SOURCE: My model #USB160 S/N
First, I would suggest you test it with another computer. This time, let it be Microsoft Windows (Xp, Vista, etc).
If Microsoft Windows (Xp, Vista, etc) does not recognize or find it as well, then it means there is something wrong with either the drive or drive case.
Read the tip brief tips about hard drives posted by me: http://www.fixya.com/support/r6506014-detect_hard_drive_working_or_not_hard
Please let me know if you need further assistance and I hope this helps.
Good luck.
Posted on Dec 02, 2010
I have a Verbatium USB160 S/N JH8Y01 When I plug it into my laptop all I get is a flashing light on the drive. It did work at one time and I was able to back up to it. I read that the usb cable that came...
Does the drive have external power (D.C.) adapter? If not try to use a 2 ended usb plug to make sure the drive is being powered up. Does the computer see the drive? go to my computer\manage\diskdrives
Jul 12, 2011 | Verbatim 160GB USB FireLite: The "drive...
No computers will recognize my externaml Hard drive. Its model number is usb160. whenever i plug it in to anything, all it shows is a flashing blue light. Can you please help?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Verbatim 160GB USB FireLite: The "drive...
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Unable to safely eject
Just completely "shutdown" your computer, and then disconnect the USB cable. Then, you should be able to manually "eject".
Apr 17, 2010 | Verbatim 160GB USB FireLite: The "drive...
Where can I get a new usb cord for my Verbatim usb160. It works if I wiggle the cord.
If your close to a radio shack they have them, you can also go to
www.monoprice.com
they sell just about any cable made and then some.
Jan 29, 2010 | Verbatim 160GB USB FireLite: The "drive...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
problem.
Go to:
1. Control Panel
the top.
a drive letter.
9. GOOD LUCK
Nov 21, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
