Question about Philips Kitchen Appliances - Others
Toaster philips hl 5215. the two external heaters are not working . Only the central one is working.
Toaster needs leaver fixing where in Brisbane
Well I hope you live in Brisbane, Australia this is what I found call service central and ask for a service company that works on toasters or powerd by trading post.com Good luck
Aug 03, 2017 | Kitchen Appliances - Others
My 1950's toaster won't work anymore!! I love that toaster and I need it fixed!
This might be more useful, it shows fixing a burnt out heater wire, without resorting to new parts:
https://youtu.be/kXn1lTYCtGs
Feb 08, 2016 | Kitchen Appliances - Others
Sunbeam vt40
Adjust the screw on the bottom which adjusts the tension created by the heaters. If this doesn't work, "bump" it some to dislodge crumbs that may be inferfering with the trip lever for the thermostat.
If nothing works, try kitchenmade usa or toaster central who both work on and fix vintage toasters.
Frank@kitchenmadeusa.com
Jan 06, 2013 | Sunbeam Kitchen Appliances - Others
Hi my toaster rotates but does not heat, what could this be?
If the heater controls were set to a temp and heaters do not heat up, the problem is either in the heater or in the control.
May 25, 2011 | Star QCS2-600H Toaster
My Krups Sensotoast Deluxe just stopped working. Can you help me? I really don't want to throw it out because it's relatively new and I expected a product with this name to last a lot longer.
The printed circuit board is likely burned out. It's pretty sad really. This is a poorly designed toaster. Krups owes us new toasters in my opinion. Looks like a fire hazard too. If you are curious, you can remove the 4 philips head screws out of the bottom of the toaster, gently pry off the push down lever and the dial, and examine the board and connections. 8_25_2012_1_16_19_pm.jpg
Mar 27, 2011 | Krups 287 SensoToast Deluxe 4-Slice...
Headset doesn't work when plugged into Mitel 5215 IP Phone jack.
You need to have a Headset button added and press it... or dial the headset on code. Contact your system admin or vendor to have the button added or to get the codes. This is something you can't do from the phone.
Jun 30, 2010 | Mitel 5215 IP Phone
Philips Toaster Oven Model HD4464/A
The glass door of an oven toaster usually are inserted in the metal slot just slightly above the hinges, so it can easily slip out and fall. try replace it with tempered glass which can be found in glass supplies
Jul 29, 2009 | Kitchen Appliances - Others
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Hello, I am looking for a part for my Hobart Toaster
parts books are available at hobartservice.com for free and the locations Hobart offices for parts
Jan 23, 2009 | Hobart ET27 4-Slice Toaster
The egg eliment doesn't work.
There is both a relay and a thermal fuse on the egg heater circuit. Could be either of them.
Jan 12, 2009 | Back to Basics TEM-500 Egg & Muffin...
Kitchen Appliances - Others Logo
70 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Robert Kilpin
Robert Kilpin
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
