Question about GE PDS18SBM Bottom Freezer Refrigerator
Food compartment not cooling adequately, door gasket loose
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 27, 2011
Lower compartment of double door fridge not cooling properly.suggest
Re-arrange the food or things inside the refrigerator side and do not block the cold air flowing. Removed unnecessary things so the refrigerator will not overload with unwanted food stuff. Be sure the door gasket is tightly seal and no deformities so that cold air will not get outside.
Thanks for asking that.
Jul 09, 2011 | Refrigerators
Freezer not cold enough to maintain ice and food
  • When your refrigerator isn't cooling your food and drink items, first check that the power cord is plugged into a working electrical outlet. If you recently plugged in the refrigerator for the first time, it will take approximately 8 to 12 hours before the refrigerator is cool. Even though the refrigerator is cool in this time frame, you shouldn't place the refrigerator to a colder setting until the initial cool down stage, which takes 24 hours.
    If the refrigerator has been running for 24 hours, you can adjust the refrigerator to a lower setting. The control panel is located in upper portion of the refrigerator compartment. Press the up arrow button to set the refrigerator to a higher setting, which will decrease the temperature of the refrigerator compartment.
  • Door
  • If the temperature control is correctly set but the refrigerator compartment still does not cool down, check the refrigerator door. First, remove any food or drink items that are preventing the door from fully closing. In addition, make sure all of the drawers are fully closed, as they may keep the door from closing.
    Next, clean off the gasket with warm, soapy water and a sponge. Rinse the soapy water off of the gasket. If the gasket is not clean, it will not create a seal with the refrigerator.
    Another reason the refrigerator is not cooling down may be because the refrigerator door is opened too frequently or left open for a long period of time. Pay attention to your use of the door and try to shorten the amount of time the door is opened.
  • Other Causes
  • Your Jenn-Air refrigerator might not cool down for other reasons. If you have recently added food to the refrigerator, the temperature of the food may have an effect on the temperature of the refrigerator. The temperature in the refrigerator will adjust after the food sits in the unit for an hour or more.
    You may have obstructed the air flow on the inside of the refrigerator with the placement of your food. The rear air grille is located under the crisper drawers. Move any food items away from the rear air grille to increase the air flow through the refrigerator.
  • If those thing above did not solve your problem you better check and replace the relay and compressor and it will be good as new. Thanks
  • Jan 23, 2011 | Jenn-Air JCD2389G Side by Side...
    Our model HRF08W frig never cooled properly (although
    Yes, there is a fan that moves cold air from the freezer compartment to the refrigerator. If this does not turn, the refrigerator compartment will not receive adequate cooling.
    If the fan is turning, you should be able to hear it. It is likely located behind an access door in the freezer compartment. This door is likely held in place with screws. Remove the screws, open the door, and see if the fan is turning. If not, you will need to replace the fan motor.
    Oct 14, 2009 | Refrigerators
    Bottom of fridge not cooling
    The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
    There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
    If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
    Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
    If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
    Hope this was helpful. Good Luck.
    Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
    Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
    In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
    If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
    Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
    If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
    Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
    We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
    Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
    There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
    Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
    It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
    Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrig not cooling
    Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
    The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
    If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
    Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
    BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
    If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
    Hope this helps.
    Jun 10, 2009 | Refrigerators
    Sub zero refrigerator freezes food
    Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
    Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
    Fresh food compartment not cold, light is lit when door closed
    Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
    Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
    GE PDS18SBM Bottom Freezer Refrigerator Logo
    83 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
