Question about AudioCodes MediaPack MP-114 FXS
The LED Uplink do not work when i connect lan cable. Therefore i cant acces interface
    Problem Solver:
  • 20 Answers
Attempted to do a firmware upgrade previous to failure? that can cause a bricked MP. Use wireshark to see if there is any sign of life when connecting ethernet cable to the interface, if there is life on earth you may still have a chance to recover it.
Posted on Nov 25, 2013
Can you connect a router to a dcm425 router
Yes. My "home" network starts with the cable-modem, with an Ethernet cable between the cable-modem and the "uplink" port on my wireless router, and up to 4 computers connected to the 'LAN' ports on the router, plus support for my wireless devices (laptop, iPhone, tablet).
Nov 10, 2013 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have the Zyxel ngg-416n wireless router. when i connect it to my cable system and the the router to my mac, the computer doesn't 'see' the network connection. so i can't load the...
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.
Also check to see if your lan connection isn't disabled on the computer.
For starters
Aug 27, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
How to connect the network cable
you will have 8 ethernet ports in this switch... One port is for input all the other ports are for output...
If you dont have any dedicated uplink port, then any port can be used as an uplink port and other ports becomes downlink port...
The Lan slot of router should be connected to the uplink port in switch.... you can connect upto 7 computers in this switch(in downlink ports)...
Dec 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Aug 31, 2010 | D-Link DSL-G604T Wireless Router
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
Tutorials On How to configure a D-Link DES-1008D Ethernet Swich
There really isn't much to setting up an ethernet switch hub. Plug a network cable into your router LAN connection and into port 1 or uplink port of your switch. All other computers will attach to ports 2 to 8. If you have an Uplink port and port 1, they usually can only be used singlely. That is to say use either the Uplink or port 1 Using both disables the switch hub.
Jun 01, 2009 | D-Link Computers & Internet
Factory Reset
Remove printer drivers
Printer off.
Disconnect LAN.
Open front cover.
Hold/press both buttons on front, keep holding.
Turn on at back.
Only release button when all lights have stopped flashing, top and bottom light illuminated.
Close front cover
Connect LAN cable.
Reinstall via add network printer - will detect and reset new IP.
Apr 24, 2009 | Lexmark E332n Laser Printer
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Wireless G Router
you should have the cable modem connected to your routers WAN port, using the lan connector cable (RJ45 plug), then using another lan cable from the router number 1 port to your pc's network lan card, making sure the uplink button is not pressed in as this is if you wish to use more than one router on your network. Go to control panel, network connections, right click on your network card>properties, then click the TCP/IP line and again click properties, then select 'obtain ip address automatically'. go to your web browser then type in 192.168.2.1 which should take you into the router settings and look for DHCP clients and make sure DHCP is enabled and save settings. Restart the pc and it should now connect.
Sep 01, 2007 | Belkin (F5D5231-4) Router
AudioCodes MediaPack MP-114 FXS  Logo
160 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
